Fast clicking turn signal
Bpzilko
William
Sarasota
The same thing is just started happening to mine. No bubls out and flashes normal on the exterior. Any resolution here?
Andrezzi
robert
PA
The same thing is just started happening to mine. No bubs out and flashes normal on the exterior. Any resolution here?l
When l changed brake light bulbs to LED also caused interior turn signal hyper flash all lights work and flash correctly on outside.
Check the brake light on the side that is blinking fast, the light bulb has died, that is the usual cause.
Colonel Angus
Dean
New York
There is a Forscan setting to eliminate hyper flash. Although it usually happens only when you change bulbs to LED.
billy
Tracey
SC
It has happened so many times on my ‘21 sport that it’s just a joke now. First time, dealer fixed it. Month or two later it happened for right turn. Then it stopped. Then it happened for left again. And now it just is so random. It will fast click then slow then fast then just random clicks. It’s quite amusing as there is no rhyme or reason.
Good luck!!
RobD59
Rob
Massachusetts
My left turn signal has started double-timing clicks. The lights are flashing normally, but the clicking is going twice as fast. ???
Any ideas?
I had the same problem, it turned out my brake light bulb was out and that affects the interior signal indicator, replaced the stoplight bulb and all back to normal now.
gvanleer
Graeme
Halifax, NS
Yep - same here - 2024 Big Bend. Left brake light out causing the left interior indicator to flash rapidly. Good to know that it detects brake lights as well as indicators. Dealer replaced the lamp at no charge.
