When l changed brake light bulbs to LED also caused interior turn signal hyper flash all lights work and flash correctly on outside.The same thing is just started happening to mine. No bubs out and flashes normal on the exterior. Any resolution here?l
Hi there! Can you send us a DM with more information? I’ll see how I can assist on my end. Thanks!
What setting? I changed to LEDs and is hyper blinkingThere is a Forscan setting to eliminate hyper flash. Although it usually happens only when you change bulbs to LED.
See this Bronco ForScan Thread:What setting? I changed to LEDs and is hyper blinking
I had the same problem, it turned out my brake light bulb was out and that affects the interior signal indicator, replaced the stoplight bulb and all back to normal now.My left turn signal has started double-timing clicks. The lights are flashing normally, but the clicking is going twice as fast. ???
Any ideas?
Yep - same here - 2024 Big Bend. Left brake light out causing the left interior indicator to flash rapidly. Good to know that it detects brake lights as well as indicators. Dealer replaced the lamp at no charge.I had the same problem, it turned out my brake light bulb was out and that affects the interior signal indicator, replaced the stoplight bulb and all back to normal now.
