- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 101
- Messages
- 5,321
- Reaction score
- 10,005
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Falken offers only one version of the A/T3W in 235/65R17, and its specs are different from other AT3/W tires it sells. This tire was specifically designed to meet Ford specs (as described in the video), and Falken doesn't sell a different version of this tire in that size. Falken lists all the specs for the different sizes of that tire on its website; it distinguishes the different sizes by what it calls "item number." I looked briefly through the list and saw only a couple of duplicate sizes (the same size tire with different specs), but the data is there. I suspect "club-only" tires are the same, i.e. if you check the manufacturer's website for a given tire the specs are readily available. If a tire reseller tells you the tire available at Costco is different from the one they sell you can just go check it out for yourself.He told me that the tires at the big warehouse club stores are not the same as what the smaller shops get.
For example:Falken offers only one version of the A/T3W in 235/65R17, and its specs are different from other AT3/W tires it sells. This tire was specifically designed to meet Ford specs (as described in the video), and Falken doesn't sell a different version of this tire in that size. Falken lists all the specs for the different sizes of that tire on its website; it distinguishes the different sizes by what it calls "item number." I looked briefly through the list and saw only a couple of duplicate sizes (the same size tire with different specs), but the data is there. I suspect "club-only" tires are the same, i.e. if you check the manufacturer's website for a given tire the specs are readily available. If a tire reseller tells you the tire available at Costco is different from the one they sell you can just go check it out for yourself.
This is not true of all OE tires. The Falken A/T3W in 235/65R17 offered as an option for the Bronco Sport is the same tire you will get if you purchase one from a tire dealer. The video does a pretty good job of explaining the reason(s) why some OE tires disappoint some customers. In some cases it's about saving money, but just as often it's about meeting a specific performance objective. Sometimes the performance objective conflicts with longevity/durability.The Dealer tires that you receive with a new vehicle are not the same you would buy from a tire shop.
That is true, but it is not the same spec as the other A/T3W's.This is not true of all OE tires. The Falken A/T3W in 235/65R17 offered as an option for the Bronco Sport is the same tire you will get if you purchase one from a tire dealer. The video does a pretty good job of explaining the reason(s) why some OE tires disappoint some customers. In some cases it's about saving money, but just as often it's about meeting a specific performance objective. Sometimes the performance objective conflicts with longevity/durability.
Look at the list on Falken's website. Pretty much all the different sized A/T3W tires have different specsThat is true, but it is not the same spec as the other A/T3W's.
Tire is not built the same as the others to save weight.Look at the list on Falken's website. Pretty much all the different sized A/T3W tires have different specs
I don't think that's what Mark meant. The ones you get as an option from the factory are the same ones offered at tire stores (spec'd the same for the same size). Cheers!That is true, but it is not the same spec as the other A/T3W's.
I've attached the list of A/T3W tires Falken sells. Look carefully and you'll see that none are "built the same" as any of the others. They were all built to meet a given spec. It may be an OE spec like the 235/65R17 (built to Ford's requirements), or one that Falken created for its own purposes. My guess is Ford wanted a tire it could market as an all-terrain tire that wouldn't negatively impact fuel economy. By all accounts, these are competent off-road tires (see video below) offering excellent road manners with minimal impact on fuel economy—in other words, exactly what Ford asked for. Are they the "same" as other A/T3W tires? Nope. But they are a truly excellent compromise for those who need decent off road capability, but don't want the downside of a typical all-terrain tire, i.e. the extra weight and poor road manners.Tire is not built the same as the others to save weight.
