Does Badlands have rear USB ports?
ajohansson
So Cal
Excursion
Can anyone confirm if the Badlands has rear USB ports? I am inclined to order one soon and the ford website is a bit confusing. I see it has a rear 110 outlet but one area says front and rear usb A and C. Hard to find pics. Its not a deal killer by any means but curious. Any help appreciated.
ajohansson
So Cal
Excursion
Ok I think I may have found what I am looking for. I found the "compare models" on the ford site. It says "Smart-Charging USB Ports - Four (4) - USB A: 1 Frt/Rear and USB C: 1 Frt/Rear". So I am assuming im good but heck if this is wrong let me know.
DesertRat
Nevada
2019 Chevy Colorado 4X4, 2021 Bronco Sport
Here you go from our Badlands / non Badlands package. (You have to be specific about the trim level). By inserting a wall wart into the AC or 12 volt outlets you can add a lot of jacks to your heart's desire.
front console phone tray area
Ford Bronco Sport Does Badlands have rear USB ports? IMG-5279
center console
Ford Bronco Sport Does Badlands have rear USB ports? IMG-5280
rear seats console
Ford Bronco Sport Does Badlands have rear USB ports? IMG-5277
rear cargo area
Ford Bronco Sport Does Badlands have rear USB ports? IMG-5278
ajohansson
So Cal
Excursion
Thanks! ok I think the Rear they must have meant inside the center console. Too bad they arent facing out the rear of the center console like above the 110 receptacle. But this is pretty easily handled with a 110 usb outlet. thanks.
Sparky
Doug
Mason City, Iowa
15 Ford Explorer Sport, 16 VW Beetle Convertible
Only the Badlands and First Edition have them in the console. The others have them at the second row where Badlands and First Edition have the second 120 volt receptacle.
thesavo
savo
Albany NY
The Ob w/o ob that I tested yesterday has usbports in the console. I think it's also in the order guide.
SLJ
Elbridge NY, USA
Be aware that only the two USBs in the front are data. These are the only ones that will work to use your phone apps on the center display. The rest are charging ports only.
Lower models have the dash and in the back seats only and have a 12 volt outlet in the dash, console, and cargo area.
Ford Bronco Sport Does Badlands have rear USB ports? USB
tRex
Rochester, NY
Other trims have USB behind the console for the rear seat -- these are also charge only -- not data connection to the vehicle (only the ones in the "media bin" under the climate controls will connect -- in any trim).
