- First Name
- Treavor
- Joined
- Apr 16, 2024
- Threads
- 2
- Messages
- 43
- Reaction score
- 37
- Location
- Fullerton, CA
- Vehicle(s)
- 2021 Bronco Sport, 1999 C5 Corvette
I have a 2021 Big Bend Sport. My apologies in advanced if this gets long-winded.
First off, I have never had a battery only last three years; I automatically swap my batteries at five years but never had one die on me in three. A little background, the vehicle went to the dealer on Aug 12th for an oil change and multi-point inspection. While at the dealer they performed the BCM recall and the SYNC-3 update. On the multipoint inspection, the battery was marked at 100% state of health. Fast forward to yesterday, Aug 23rd, got in the vehicle to go to work in the morning and I got a message stating the vehicle was in battery saver mode, thought that was a bit strange as I didn't see that anything got accidentally left on all night. I attempted to start the car and it started without any hesitation, 100% normal. Then, eight hours later, after work, went to go home, no messages on the screen, however the car would not turn over....the battery measured just a touch over 10 volts using a voltmeter. Anyway, jumped it and drove home. When I got home, after an 18 mile drive, I put my battery tester on and it showed 22% state of health. I am trying to figure out how a battery goes from 100% to 22% in 11 days. Any changes to the BCM with the recall that would increase the drain on the battery? This vehicle is my daily driver, it does not sit for long periods of time without being driven.
I replaced the battery this morning. When purchasing the battery, I found this vehicle requires an AGM battery, which makes sense. However, nowhere on the OEM battery that I pulled out did it say that the OEM battery was an AGM; it was, however, marked "lead acid battery". Did this vehicle have the wrong damn battery in it from factory? I am thinking yes it did and that is why it only lasted three years. For those of you that have changed your battery, did you notice if your OEM battery was labeled as AGM?
When I pulled the air box out to remove the battery, I found a leak. At first I thought this might just be road grime but everything else around it is super clean. The unit right below the air box is labeled as being the all-wheel drive unit. There is a big area that is wet with oil or grease, this is fresh as it was wet and not dry. I also found some liquid in a couple of low spots, it was very thin, like water and had no smell....it may be water but don't know how water could have got up in there. There is a tube, with a cap, sticking up out of the drive unit which I believe is a breather....I am pretty sure the oil is coming out of it. For those members that have had to change their battery, have you seen this (please see attached pictures) under your air box? There should not be any oil coming out of that breather.
Again, sorry for being long winded, just wanted to provide as much information as possible in hopes to get some good feedback and be armed with information before calling the dealer on Monday. Any information would be very much appreciated.
