Custom SSC2 Grille Mounts
Trist0n
The Moon
2021 First Edition // 2022 Outer Banks + OB
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4352
Howdy all! Putting my toggle switches to good use. Had to get a little creative with the CAD for this one, since there’s no easy way to access the underside of this plastic. Obviously stole a lot of inspiration from the Rough Country light bar mounting, but this won’t interfere with my ACC like that one does. These are combo SSC2 pods by diode dynamics, so they’re both wide beam fog lights and long reaching spots in yellow. They have amber backlighting that I’ve got on its own switch.
Designed in F360, printed in carbon fiber PETG (Nylon was being a pain, if it doesn’t hold up I’ll revisit the material but it should be more than sufficient)
Reference my other post on toggle switches for how I wired and control these, they tie into the same system. The bright beams and backlights have dedicated switches, though I may move the backlights to trigger with the DRL’s if I like them enough
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4336
Bolts through the side plastic of the grille, clips underneath to hold everything in place
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4341
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4342
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4347
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4346
Ford Bronco Sport Custom SSC2 Grille Mounts IMG_4351
Mwittke5857
Elma, NY
2021 Bronco
I need to get busy with this 3D printing. Retired so time isn't an issue
Javier
Miami, FL
@Trist0n Love it!!!! Will you be making these to sell? Or I can pay you something to share the file and I can ask my buddy to print a set for me. I am sure you put some time into this, so if you wanted some kind of compensation for your time, I would fully understand.
hcrews1955
Hilton
Purlear, NC
If you decide to sell a set. I''m a buyer.
