Cornering lights enabling 2025+ WORKED!
This is easy. You just need to activate them in the BCM.:clap:
Ford Bronco Sport Cornering lights enabling 2025+ WORKED! image_2026-04-25_18-49-58
This doesn’t work for me. Just came outside to try it.
I even rebooted the BCM module.
Stircrazy
BC, Canada
Why do you run your fogs all the time? I find my lights so bright I feel guilty.
you realize the driving lights are only lighting up the short distance ahead and the side ditches. thoes are not going to blind anyone thats why they are able to be activated with the low beams. what I did was change it so they can operate with the high beams also, there is no better combanation than hi's with driving lights when going down a old secondary road where there are lots of critters to hit.
Garth
Garth
Ontario
They will be paralyzed with blindness lol.
Seriously though I have a pet peeve with people in pickups driving around with their fog lights on and pulling a trailer or a load in the back enough for their lights to be shining into my eyes like a wall of light.
Just like with new Canadian truck drivers putting extra auxiliary lights on, I figured it was from growing up in third world conditions and malnutrition caused some sort of night blindness.
Ya I still can’t get this to work on mine. Idk. Bummer
Iamcanadian
Ontario Canada
I did the same with forscan, activated Bambi mode so minor on all the time then I went one step further and activated my fog lights to be on with my daytime running lights so I have two extra lights during the day just for that extra added bit of visibility. I pulled into the parking lot the other day when I was meeting my buddy for coffee and he mentioned it right away that my little Bronco stands right out when I pulled in because of the lights. Not something he would typically notice or mention but it did catch his eye.
I tried that too. And for some reason, none of the fog light changes are working on mine. I don’t understand it.
Iamcanadian
Ontario Canada
Are you trying to change the hexadecimal codes or are you doing an easy mode where you just select an option and turn it on or off? I find things work better in easy mode than they do in hexadecimal mode
I’ve tried both ways, which is why I’m incredibly confused haha
Garth
Garth
Ontario
Bright lights are bright lights
pantera155
pantera155
Pantera
Argentina
Bronco BADLANDS 2025
For it to work, the gearbox must be in D. If it is in P, the corner lights will not turn on.
I only did it with easy mode
…I swear to god… I never thought about this. 🤦🏻‍♂️
If this is the solution I’m going to lose my mind. 🤦🏻‍♂️
