Wheels are very sharp , what offset did you have to go ? Those flares are perfect. ?I go with 245/70R17
Thanks I did go with offset -33Wheels are very sharp , what offset did you have to go ? Those flares are perfect. ?
I hope BFG is slipping you some coin with that advertising your doing, lolI go with 245/70R17
? no I don’t think so lolI hope BFG is slipping you some coin with that advertising your doing, lol
I love my BS in the street, on the road and off-road. I'm still learning the best setting in the GOAT dial when off-road.
I got the lift kit from Eibach.
PRO-LIFT-KIT
2021-2023 Ford BRONCO SPORT Badlands 2.0 T AWD C2
+1.0" Front | +0.7" Rear
Part #: E30-35-053-03-22
Set of 4 Springs
Comment: DESIGNED FOR USE WITH OE SHOCKS
Now I'm not sure about the tire size.
Should I go with 245-75-17 since I'm not planning to change the wheels.
Here's how it looks with OE tires
From my understanding it's only required if you lift the rear over the base 0.7 inches, I think.May I ask if you used the Pro-alignment kit? Eibach says this is required if lifting.
No I didn't even though I got it, the dealer didn't need it, they used the OEMay I ask if you used the Pro-alignment kit? Eibach says this is required if lifting.
See photoIn that pic those tires look too big, even though you don't offroad they will rub at some point, awfully close to the backside of the front wheelwell.
Yes correct or 1.75” then its true 2” lift?This.
What lift did you go with?
Looks like a 2"
What kit did you decide on?Yes correct or 1.75” then its true 2” lift
.? Do you know the true diameter of your 245/70/17 .?This.
Looks like a 2"
