BS Badlands Lift kit
SgtT11B
El Segundo, CA
I love my BS in the street, on the road and off-road. I'm still learning the best setting in the GOAT dial when off-road.
I got the lift kit from Eibach.
PRO-LIFT-KIT
2021-2023 Ford BRONCO SPORT Badlands 2.0 T AWD C2
+1.0" Front | +0.7" Rear
Part #: E30-35-053-03-22
Set of 4 Springs
Comment: DESIGNED FOR USE WITH OE SHOCKS
Now I'm not sure about the tire size.
Should I go with 245-75-17 since I'm not planning to change the wheels.
Here's how it looks with OE tires
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162922345
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162909344
Ford Bronco Sport BS Badlands Lift kit PXL_20231105_162947529
May I ask if you used the Pro-alignment kit? Eibach says this is required if lifting.
Ford Bronco Sport BS Badlands Lift kit 1701980499544
The Rinzler
Tony
Everett, WA
From my understanding it's only required if you lift the rear over the base 0.7 inches, I think.
In that pic those tires look too big, even though you don't offroad they will rub at some point, awfully close to the backside of the front wheelwell.
See photo
Ford Bronco Sport BS Badlands Lift kit IMG_1386
gatornek
Miami
To the OP, now that they've been on a couple of months, are you still liking "the feel" of the Eibach lift kit compared to the stock BS suspension???
