They really should just add it to a Sync update.I wish it was like the other cars we have... Just turn the feature off in the settings. No programming needed. Plenty of space on the screen below Autolamps!![]()
Yes. Instead of the high beams coming on full blast, and off full blast. They fade on (about 2 seconds) or fade off (about 1 seconds).fading high beams?
Does it actually work?Good news!! found the AHB Fade setting in forscan, it was in the bdycm section
unfortunately, it didn't seem to workDoes it actually work?
I've been looking into this. I have a 21 OB without B&O. I upgraded my speakers a while back and you can definitely tell the rears do not have the same output levels as the front. Low levels in particular. The current forscan version only has the As Built ACM for my vehicle and I haven't found anything reliable yet to change the EQ.Anybody do any more experimenting with Forscan stereo mods?
Check the other thread in this subforum and see if changing the ACM As-Built code works for you as well. My girlfriend (who primarily uses the Sport) and myself felt a difference in audio but I want to hopefully hear from others as well.I've been looking into this. I have a 21 OB without B&O. I upgraded my speakers a while back and you can definitely tell the rears do not have the same output levels as the front. Low levels in particular. The current forscan version only has the As Built ACM for my vehicle and I haven't found anything reliable yet to change the EQ.
