Bronco ForScan Thread
brianloch1974
Brian
Butler, PA-USA
2022 Bronco Sport Big Bend
So I done goofed. Tried changing wheel size and BBB did not like it. I went back to ab file and now have the following... Can anyone help? Thank you in advance.
Ford Bronco Sport Bronco ForScan Thread Screenshot (11)
Ford Bronco Sport Bronco ForScan Thread Screenshot (12)
Ford Bronco Sport Bronco ForScan Thread Screenshot (13)
Ford Bronco Sport Bronco ForScan Thread Screenshot (14)
tburner
Troy
DFW, TX
If you've reset back to factory values, reset your fault codes by clicking the yellow triangle with the power button symbol (circle intersected by a vertical line at the 12 o'clock position). Report back whether the codes returned.
Note: if you don't know already, after you update your tire circumference, you have to run a relearn on the PCM and AWD modules.
Sidebar: Holy shit you have way more modules showing up than I do on the same version of FORScan.
brianloch1974
Brian
Butler, PA-USA
If you've reset back to factory values, reset your fault codes by clicking the yellow triangle with the power button symbol (circle bisected by a vertical line at the 12 o'clock position). Report back whether the codes returned.
I greatly appreciate the reply. I did the relearn for both modules as per the tutorial. I may end up at the dealer. I didn’t see any difference but 1 value change between the dl ab vs what I saved. I went and changed the dl ab file from ford and did the change manually and it had no affect.
Ford Bronco Sport Bronco ForScan Thread 1657501591736
tburner
Troy
DFW, TX
Any luck resetting the fault codes?
brianloch1974
Brian
Butler, PA-USA
I did however get the cabin exit honk disabled. And parking lights with drl’s. At least that worked for me.
tburner
Troy
DFW, TX
It’s acting like I replaced the entire PCM. That shows the VIN mismatched.
Seems like the PCM doesn't want to communicate correctly with the rest of the vehicle. How many times did you try the PCM relearn? Maybe something misbehaved during your last relearn and it's freaking out?
brianloch1974
Brian
Butler, PA-USA
twice
tburner
Troy
DFW, TX
DL from Ford.
Hmm. I'd recommend comparing your current as built to what was downloaded from Motorcraft to see if it carried over correctly. I had problems with the Motorcraft as built a little while back. And double check the VIN used to download from Motorcraft was the correct VIN.
brianloch1974
Brian
Butler, PA-USA
Restored successfully! Thanks for helping. I had 3 values to change. All good. Now to shut that damn cabin honk off... I WILL NOT BE DOING THIS AGAIN LOL
tburner
Troy
DFW, TX
Glad you got it fixed! What a weird problem to run into... I'd suggest making a backup of your functional as-builts.
