Broken Drive Belt at 1,450 Miles
tjbronco
If you check the owners manual, these engines have a very unusual feature. They can run with no coolant for an extended amount of time. The engine will automatically alternatively disable the cylinder's and use the current non-functional cylinder to cool the other two by pulling in only air. Performance is obviously reduced, but the manual says you can continue driving and find a service station. So I doubt you have any damage from overheating.
Most likely (going by cars I have had in the past) the water pump locked up and destroyed the belt.
KLaneAbel
Kara
Louisville, Kentucky, USA
I just got my Big Bend on September 2, 2002 then on October 11th I was driving when I started losing power and several warning message started flashing including overheating. I pulled over as soon as I could get to a parking lot, which was only about 1/4 of a mile away. I then noticed coolant all over the front passenger side tire. After being towed to the dealer I just found out today that the main drive belt completely broke and took the water pump out and caused a leak. They are trying to figure out what caused the drive belt to break. It has to be a defect of some sort because the car is brand new. I am concerned that I may have engine damage from it over heating and going in limp mode. It is disconcerting all these issues are happening. Has anyone had a similar experience? I feel so helpless. I just made my first payment and don't even have my Bronco. I have contacted Ford Corporate and they have escalated the ticket.
Update: They replaced the missing serpentine belt and once it was back on, they said everything went back to running normally. They didn't see that the water pump was damaged, I was told the pressure built up when the belt came off and it sprayed coolant. They have no idea why the belt came off. Blamed it on manufacturing and said it most likely wasn't tightened or aligned properly. They are rushing to produce cars off the line and QC may have missed it. Who knows, but it seems to drive ok this evening.
Good news its up and running again.
fourthgear
florida
I know it happens but the drive belt did not have any wear so the question becomes what would make the drivebelt break.
A bad belt , they are massed produced , there is an acceptable manufacturing failure rate .
Sounds like the safeguards Ford built in to the powertrain control module protected your engine as intended. To be on the safe side, watch your coolant level closely over the next few months. If there's an issue with your water pump or head gasket (common victims of overheat) it will most likely manifest as a loss of coolant.
Broncky_Alto
Christa
Came across your post as I am waiting for a tow for the exact same thing…how did it turn out for you? Very scary as I am on the highway.
