- First Name
- Major
- Joined
- Mar 5, 2022
- Threads
- 16
- Messages
- 1,208
- Reaction score
- 2,881
- Location
- Right Here Right Now
- Vehicle(s)
- Bronco Sport aka "Spark Plug"
full syntheticsThe source is watching a boost gauge while driving a 2L turbo for the last 10 years. For normal driving the system is not in boost, it’s in vacuum. Only under moderate acceleration does it even move from vacuum to boost. You really have to push pretty far down on the accelerator to get far into boost. The turbo is always going to be hot because all of the exhaust gasses are running through it. So what we are talking about is just how hot it is. I’ve read many times over the years the advice I gave above. If this was truly an issue to be concerned about on these small turbo engines, there would be turbo failures piling up. Do turbos fail, yes. Are they failing at a high rate, no. Most drivers pay no attention to this and never will, which would lead to a higher failure rate if it were an issue. Airplanes work pretty hard during landing so I can see where they would need a cool down period. Most cars are driven easy in the last minute or so before getting parked. It’s really only at the extreme that you need to consider this cool down. After all that, if you want to sit in the car and let it idle, and that makes you feel like the turbo is being taken better care of, then by all means.
low volatility
not an issue of debate
hot shutdowns was the focal point
spindle seal/bearing contact closest to the heat source
potential for residue hard to ignore
cool down just long enough to finish listening to "hey joe"
