Body work
LDM67
Indiana
2021Ford Bronco
Knocked antenna off which put hole in roof of Bronco backing out of garage. Does anyone know if this is something a body shop can repair or if only dealership can?
Ford Bronco Sport Body work IMG_3610
Yes, a body shop can repair that. Flatten the metal around the hole, install a doubler on the inside, then mount a new antenna to cover the ragged hole. You'll have to be very careful about sealing around the new antenna to prevent water intrusion.
LDM67
Indiana
2021Ford Bronco
Okay, thank you for the response.
LDM67
Indiana
2021Ford Bronco
With my luck it better be really stubby.
Topo
Jeff
Pennsylvania
There are two stubby antenna choices a 4" and the 2" stubby junior.
The 4" interferes with a ski box if using low-profile crossbars.
But the 2" compromises signal reception.
Go to radio-locator.com to see a signal strength map based on your location.
Thom at Cravenspeed was helpful.
I ended up with both the 2" and 4" to swap out.
Why Ford uses such a primitive antenna design is beyond me.
LDM67
Indiana
2021Ford Bronco
Okay thanks, I’ll check it out.
How did you get it in the garage with no damage, but backing out did this? The antenna must have been hitting any time you parked inside. Just curious.
davidg4781
Does that antenna do anything else besides AM/FM/XM/Cellular?
I'd like to be able to keep navigation 100% ready but really don't need anything else.
Mrmike
Syracuse, New York 13219
I have a 4" on my '23 OBX. The factory nav works just fine. It has got me on 2 (1000-mile) trips so far with no problem. I can pick up my local stations with no problem and use Sirius when traveling.
JimC
jim
SE Michigan
2019 Ranger 2022 Bronco Sport
I did the same with my ranger, went to dent doctor. He did a great job on it & all I needed was to have antenna reinstalled.
couple years now no issues at all
