Bigger tires and handling
OK, the Continental came with 8/32" tread depth and the Goodyear Forterra HL, with 10/32", so not a huge actual difference but still a 25% increase.
Um that be 20% ?
My move from my slick, hydroplaning 225 stock Conti’s to my 235 Yoko Geolandar GO15’s had me dropping the cold tire pressure one pound to 32 psi, for the best handling and tire road feel.
At my first 5k tire rotation my tread depth gage across the tires tells me I’m right with the psi.
On a sixty degree day once they reached operating temps they were 36 and 37 psi anyways.
This same tire in a larger size on my 2004 Ford Escape needs only 30 psi for proper tread wear and handling,
30 psi is on the Escape’s door plate for cold tire pressure. Odd until you think it through this larger size @ 30 cold they’d still get up to 35,36 hot, only one psi less than my Bronco sports cold setting of 32 psi. As for thinking it through,Our side walls are our tires cooling surface, radiator. Larger sidewalls dissipate more heat. I bet there are boat loads of data on that subject so let’s pass on this aspect.
I’ve had several other vehicles, from low profile Pony Cars and Camaro’s to Full height and raised F-150,s to 2x4 and 4x4 Toyota pick ups that needed three, four and even five psi over door data cold tire psi’s to handle and wear correctly.
OP, start at 32 for a week, let the tires break in and wear off the new tire chemicals,,, two weeks in the cold weather.
Then slowly go up just ONE single psi each week, ok skip the 33 and next go to 34 psi, then 35.
My Ford dealer likes to set tires, all tires at 35 to 36 psi saying we have lots of twisty roads and people don’t slow down enough to run door stated pressures.
Raising Center of gravity or changing roll out (Engine RPM vs tire revolutions per mile, gear ratio’s at a given speed) more than as little as possible is why I won’t go over/above a 235 tire on my Base model. Because I don’t want my little 1.5 L working harder than it needs to by changing the gear ratios or mounting inch heavier tires. Fwiw my 235’s weighed four pounds each more than the stock Conti’s.
Slow down , way down in the corners, always.
Play with your pressures, let those big comfy new shoes break in.
And remember to ponder all this on the ‘Tree of Woe’..
Sorry, just couldn’t help it :’P
gcallen
Grace
New Mexico
What kind of lift did you install? Could be the sway bar , I had a ready lift that used brackets to connect sway bar links and the handling was awful. I replaced it with hrg lift and made a world of difference. I have 235/60/18 had them before lift and after lift and there is very little difference at all.
I went with the ReadyLift too. Funny enough I just brought it back to the shop today because the handling was getting worse (possibly misalignment) and it started to click on me pretty badly. Depending on how it does after today, I look into getting the HRG…
Adam06
Adam
New Mexico
Bronco sport big bend
Hope it works out for you, readylift sent me one of their old first kits that came out. The spacers don’t have the cut out for the strut hat which does not allow the strut hat flex . So you get the clank sound. They swore up and down. The kits were all pulled and updated to the new spacers. Even said the serial numbers would confirm it. But sure enough they were not. 4wp did my install and refused to check it. Took it apart myself and found out they were wrong.
Ford Bronco Sport Bigger tires and handling 0574B78D-A44F-43E4-9876-79E2CCCCF597
Ford Bronco Sport Bigger tires and handling 6B5499A8-BC15-4378-B309-F9D82A211AA5
GoatsyBanks
Josh
New Hampshire
I'm planning on getting the hrg (thanks to everyone's feedback) and what you are showing is extremely helpful in doing it right the first time.
How are the struts to remove? I did it once on a 2012 edge and it wasn't very much fun.
Adam06
Adam
New Mexico
They were very easy, I bought my self a breaker bar to get tough bolts loose. If you get the hrg lift make sure you get the camber bolts they will be needed for proper alignment. There is a video on YouTube that shows the install for the hrg lift.
AndyMac204
Andy
After much back and forth I think I am settling on the HRG lift once the tires I have wear down. Not sure about the 235 vs 245 debate, but I am leaning towards the bigger ones.
245's is where its at. even without the lift installed yet, it looks way better.
c'mon dude, all the cool kids are doing it.
Dangerduane
Duane
Albera Canada
I have 1.5 inch ready lift with 265 60 R18 cooper rugged treks. offset rims . handles great. A lot of trimming to make fit but i think it handles better
Dangerduane
Duane
Albera Canada
Ford Bronco Sport Bigger tires and handling 20220428_141432
