BFG KO2 daily psi
B-Dog15
Brandon
Covington, Ky
I’ve been driving around now with the BFG KO2’s in 245/65r17 for a good while now and I absolutely love them. They did feel really firm at first but I realized they were at like 45 psi. I dropped them down to about 35 psi and I the ride comfort has felt great.
My question is for those that also run the KO2’s in that size what psi are you running at for your daily driving? Is 35 psi too low for these tires? Might be a dumb question but I appreciate any feedback!
I believe 35 psi is fine. I ran that on my Jeep Liberty with KO2s. The load rating on tires is based on inflation, the higher the load, the higher inflation should be (without exceding max inflation rating on the tire). The BS is a fairly light vehicle. Check you tire wear. I overinflated my trailer tires and wore out the center in just a couple of thousand miles. The trailer tires are rated for 90 psi, and I had them inflated to 40. Trailer was designed for a much heavier boat.
Big Ben
Rick
Calgary
It doesn't matter what tires you have. Go by the door sticker that says 33 lbs. cold.
B-Dog15
B-Dog15
Brandon
Covington, Ky
I’ve heard this but have also seen people say that it’s more tire specific rather than vehicle specific… I’ve looked for a recommended psi online on some different places but couldn’t get a definitive answer so maybe you are correct in that the 33 psi is what is best regardless of tire!
At least one of Falken Tires post provided the information
I think it is in this post but it’s pretty lengthy.., hope you find the psi info..
Look for “load capacity” here:
https://www.broncosportforum.com/forum/threads/hello-from-falken-tires.4072/
Big Ben
Rick
Calgary
All tire manufacturers have psi tables basd on weight load if you want to go by that. KO2’S are designed to ruN as low as 10 psi, I believe, offroad, so 33 is more than adequate for a light vehicle.
I don't have K02's but I do have 245 65 17 Falkens and I run 33psi, anything more and the Badlands starts to get bouncy.
I do have 35/12.50/15 K02's on my Toyota 4x4 pickup, in the rear tires I run no more than 20psi. The rear is so light when not carrying anything substantial in the bed anymore air in the rear tires makes it ride like having Flintstone rock wheels.
Try this:
https://tiresize.com/pressure-calculator/
Myrtle Beach
2024 Bronco Sport
you can always do the chalk test.
air your tires to desired psi, draw a line across the tread with white chalk, drive around awhile, and check to see where the chalk has worn off, if evenly worn off, you're good,
if not even, continue to adjust until you find the right pressure
I dont have KO2's, I do have 245 65R 17 Falkens, I run the standard 33psi, I have tried running more psi (too bouncy) and less psi (poor handling).
I have 33600 miles on the Falkens and they are wearing evenly without issue.
I rotate them at every oil change which is every 5000 to 7500 miles depending on conditions.
Deleted member 12075
From what I recall from the last tires I purchased, it doesn't mater the make (or size apparently) Tire Rack advised me to keep the tires at the pressure posted on the vehicle. In my case, I would run them at the recommended 33 psi on my BB
