Apple CarPlay broken?
Rob Binsky
the West
2025 Bronco Sport, 2023 full-size Bronco Wildtrak Sasquatch
This has been going on for about 2 months; with one big Bronco and two different Bronco Sports; in 2 different locations; but with the same iPhone. CarPlay connects, but randomly the map will not show, or the map shows but the navigation won’t work. I’ve tried both apple map and google map. The only gps that works as it should is the installed Sync, which is free for a while, and then a paid subscription. I can’t tell if it’s my phone, Verizon, or Ford.
i’ve followed a couple youtube videos, i.e., unpaired and re-paired the phone, turned off VPN, reset phone, reset Sync.
Anyone have any insight on this?
Jmuns
FL
2022 Bronco Sport BL
Do your maps/navigation work on your phone if you aren't using Carplay? Sometimes I have to open the maps app on my phone to force Carplay to work as it should. I'm always on beta software though so I never know if it's the beta iOS or just Sync and Carplay both being subpar platforms
thomasm23
Los Angeles Metro
How about sharing some information with us.
Year of your BS
iOS version installed on your device
What type of USB cable? USB-C to USB-C?
What brand of USB cable?
I've been having issues with my wireless Apple carplay also over the last couple of weeks.
Map apps seem to work ok but Pandora & Spotify will sometimes open on my screen, the song will appear but it will not play. No control to move to the next song.
Sometimes after a shutdown and then a startup cycle they will work.
I haven't done much to try to figure it out yet, that is re pair Sync and my phone, etc.
I phone 14 pro max, IOS Version 26.5.2 and Sync 4 with the latest OTA update.
thomasm23
Los Angeles Metro
Current iOS version is 26.6
Rob Binsky
Rob Binsky
the West
Year of your BS
2025 Outer Banks Sasquatch. IOS version 26.5.2 on iPhone 15 Pro. Doing it wirelessly, not using cable.
Negative. I was going to try a couple of things after the IOS update.
It worked normally this morning so I 'll see how it plays out.
DWG
New Jersey
Wondering if It is a Sync 4 issue. I just used CarPlay on my 24 BS with Sync 3 with no problems.
thomasm23
Los Angeles Metro
After updating to iOS 26.6, check the following.
On your iPhone, tap on Settings, scroll to General, tap General, scroll down to CarPlay, tap CarPlay. Make sure Allow CarPlay While Locked is on.
Also make sure under Apps, that your Maps apps are selected.
After that, on your center screen, tap Settings, scroll to CarPlay, tap Apple CarPlay, select your device, make sure Apple CarPlay in on and Show on connection is turned on.
