- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 73
- Messages
- 4,201
- Reaction score
- 7,474
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Following advice and information from tburner--thanks Troy!--I purchased and installed an auto-dimming mirror with a compass and Homelink. I ordered the mirror from Kia World Parts (link in Troy's post) using a VIN I copied from an ad for a Kia Optima on Autotrader. The mirror was under $13, and with shipping it was less than $30. I also ordered the mirror extender (Advent Gentex Mirror Extension Mount GENMM5) from eBay.
I started by prying the cover off the Copilot 360 components above the mirror. You have to give a really good tug to get it to release. I would not pull down in the middle; the attach posts are on either side, so pull there. Once you get the cover off you can loosen the screw that holds the OEM mirror in place and remove it.
My car did not have an OEM dimming mirror, so there was no connector under the cover. I snipped the connector off the back of the mirror and installed the female side of a Molex 4-pin connector. Next. I installed the mirror extender, then the mirror. For the wiring I followed Troy's data on the mirror's wire leads. I had some different colored wire lying around which I used to fabricate a wire bundle. You'll only need two wires (power & ground) for your wire bundle. I installed the male side of the Molex connector to my wire bundle, with the power lead connected to pins for the mirror green & white wires, and the ground lead connected the mirror ground. After connecting the two halves Molex connector together, I routed the wire bundle along the headliner, down the passenger-side A-pillar, and behind the door trim pieces to the passenger-side fuse panel. I had already routed wiring for a dashcam along this route, so it easy the second time.
With the wiring bundle routed to the passenger-side fuse panel I spliced the power lead into the same piggyback fuse connector powering the dashcam, and the ground lead into the ground connection used by the dashcam.
Thanks again to Troy for doing all the legwork and making this job much easier!
