Ford is no longer on the forum. You may want to consider editing out your VIN (it's not something you should post publicly as a general rule) or deleting the post altogether.Can you check our Bronco out?
How do I delete it?Ford is no longer on the forum. You may want to consider editing out your VIN (it's not something you should post publicly as a general rule) or deleting the post altogether.
Can you delete your reply with my vin. no.? Thank you.Ford is no longer on the forum. You may want to consider editing out your VIN (it's not something you should post publicly as a general rule) or deleting the post altogether.
Before he deletes it, your truck is reporting a TON of codes. Hard to pin-point exactly what is causing the errors. See attached (VIN is removed).How do I delete it?
Thanks! It's at the dealership getting checked out. We dropped it off running so hopefully they can figure it out. It was running fine but concerning.Before he deletes it, your truck is reporting a TON of codes. Hard to pin-point exactly what is causing the errors. See attached (VIN is removed).
A lot of the codes went from active fault to stored codes after the initial event occured circa 1:38pm. I'll edit the post in a bit to include which codes are still showing as active faults.
Edit: The codes below are still showing as active faults as of about 40 minutes ago when it last reported data to the cloud:
I can't tell what caused ths issue based on this info. This will need to be properly diagnosed by plugging into the vehicle. There were hard faults before in the GSM, IPMA, AWD module and the RCM.
They have access to the same things I do and more, so they'll be able to see that, too.Thanks! It's at the dealership getting checked out. We dropped it off running so hopefully they can figure it out. It was running fine but concerning.
Thanks again!They have access to the same things I do and more, so they'll be able to see that, too.
