21 bronco sport error power train malfunction
2025 Badlands Sasquatch
Can you check our Bronco out?
Ford is no longer on the forum. You may want to consider editing out your VIN (it's not something you should post publicly as a general rule) or deleting the post altogether.
winn70
Nth Iowa
2023 Ford
How do I delete it?
Can you delete your reply with my vin. no.? Thank you.
rugedraw
Javier
Miami, FL
How do I delete it?
Before he deletes it, your truck is reporting a TON of codes. Hard to pin-point exactly what is causing the errors. See attached (VIN is removed).
A lot of the codes went from active fault to stored codes after the initial event occured circa 1:38pm. I'll edit the post in a bit to include which codes are still showing as active faults.
Edit: The codes below are still showing as active faults as of about 40 minutes ago when it last reported data to the cloud:
Ford Bronco Sport 21 bronco sport error power train malfunction 1775772650047-k
Ford Bronco Sport 21 bronco sport error power train malfunction 1775772699542-q1
Ford Bronco Sport 21 bronco sport error power train malfunction 1775772719917-v9
I can't tell what caused ths issue based on this info. This will need to be properly diagnosed by plugging into the vehicle. There were hard faults before in the GSM, IPMA, AWD module and the RCM.
winn70
Nth Iowa
2023 Ford
Thanks! It's at the dealership getting checked out. We dropped it off running so hopefully they can figure it out. It was running fine but concerning.
rugedraw
Javier
Miami, FL
They have access to the same things I do and more, so they'll be able to see that, too.
