I can tell you when looking for spacers a 2018 focus st had the same dimensions you need, center bore and lug pattern.ay help looking them up. If you look aty pic the ne on the spacers is who I purchased from. This was the second set Ive got from them.
Nice look .
Ford Bronco Sport 20mm wheel spacers installed 0C10B519-13AD-4AC7-AE7B-C2EAFB7003E5
RogueRodney
Rodney
McKinney, TX
RogueRodney
Rodney
McKinney, TX
RogueRodney
Rodney
McKinney, TX
Jrl: The spacers you referenced if ordered as 25mm front/25mm rear are just that (from what I was told) 1 front, 1 rear, so you would have to order both.
I went with this one:
https://www.titanwheelaccessories.com/products/1-25mm-titan-wheel-spacers-for-ford-bronco-sport-escape-5x4-25-5x108-63-4-hubcentric-12x1-5-studs-set-of-4?variant=42193355636894&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQiA5NSdBhDfARIsALzs2ECrmOnYeRVn4_HeI69zkX7aJ7axFH17SzEDELzH6VxUFmhdLENsPnAaAiWEEALw_wcB
As the website said they worked (I'm sure the others would based on what Dakman said). These are single items, that MUST be ordered in twos (yes that is weird), but you would need 4 anyway...
Reactions: Jrl
dakman
dakman
Anyone know if this is for a set of 4 spacers ? (163.00)
yes, in the drop down menu you have more options
Scot
scot
south texas
2022 Bonco Sport Big Bend
When I purchased my BB the first thing I knew was it needed different wheels and bigger tires. Being such a new vehicle the wheel options were short and out of stocks were normal because of supply issues. I like the wheels I got but they were fourth or 5th on my want list. Everything was backordered for like 6 months I couldn't wait. I settled for a 7.5" rim with 35mm offset. I don't want my tires sticking way out but wanted just a little more. Before buying new rims I picked up some 20mm(3/4") hub centric spacers. I drove my BB for a week with spacers and stock 18" 225 tires. Looked way better but it improved the handling tremendously. With my other wheels and 245's it's awesome. I may see if I can find a real lightweight wheel I like since I plan on no hardcore wheeling and get rid of the spacers. I would now be looking for a 8-9" wide wheel with a 30 mm offset which should put about where I'm at without the spacers.
Ford Bronco Sport 20mm wheel spacers installed PXL_20221125_224220752
Ford Bronco Sport 20mm wheel spacers installed PXL_20221127_204109931
Ford Bronco Sport 20mm wheel spacers installed PXL_20221127_204037531
Ford Bronco Sport 20mm wheel spacers installed PXL_20221127_204045087~2
Ford Bronco Sport 20mm wheel spacers installed PXL_20221127_204021965
Nice .... I just got a new 2022, just like yours less lights and tires. I do appreciate your info.
is that factory height ?
dakman
dakman
It has a 1 1/2"HRG lift.
Douglas
South Dakota
2021 Bronco Sport 2023 Escape Platinum
Just installed the Titan 25mm spacers. Went on like a dream. Look to be well made also. Made my BB really aggressive.
Just to let everyone know, adding this wheel spacer does reduce the maximum tire size you can install before getting some rub on the pinch weld. My Toyos are on the small side of the 245/70/16 specification (about 29" diameter) and I do get a rub that was enough to go through the liner right at the weld flange. For those that don't know the 245/70/16, 245/65/17, & 245/60/18 would all have a 29.5" diameter per the specs.
Douglas
South Dakota
Using wheel spacers not lift kit. Tire height remains the same limits. Can run wider not taller.
galavoxx
Randy
San Francisco, CA
I am running 245/65 r17 Wildpeaks. It sounds like I can run spacers with my tire size and the smaller factory recommended tire sizes and a 1.5" lift and will not experience any rub. Is this correct?
Reactions: Jrl
On your badlands with a factory lift that comes with all the extras that a badlands has . You will not need an additional lift unless you are doing some intense off roading . Everyone runs 245/65/17 with not an issue. .Just waiting for mine to get a few more miles on my 235/65/17 wild peaks . Unless you want to run 70, s like Eric installed on that cactus gray badlands , which by the way , one of the nicest badlands in our little group . My thoughts .
Ford Bronco Sport 20mm wheel spacers installed 3EDB6B11-9FFF-48DA-99FD-52CC19440829
Ford Bronco Sport 20mm wheel spacers installed CF6A7CE5-226D-4F4D-9158-EEF9B633E4FE
Ford Bronco Sport 20mm wheel spacers installed A32A4476-70A2-4B01-AC20-885A18E99704
Height isn't the issue in this circumstance. When you add wheel spacers you change the positional relationship between the tire tread and protrusions--such as the pinch weld--in the wheel well.
