Horn Replacement
Andrezzi
robert
PA
Any body replace there horns with F 150 horns or something louder than our Sport horns.
Benanza
Ben
NJ
Horn Blaster Train horns with air hose adapter. Tank and compressor installed in spare tire area. Air line and wiring thru the pillars up and in split horns to each side. I wire tapped the main horn so it goes off even for the alarm.
Ford Bronco Sport Horn Replacement PXL_20210921_180832815
Ford Bronco Sport Horn Replacement PXL_20210921_181323204
Ford Bronco Sport Horn Replacement PXL_20210921_181326051
Benanza
Ben
NJ
I bet your neighbors just •adore• you if it goes off accidentally. :)
Only happened once when the remote was in my pocket. Most times I walk in and drop them on the table so it's not an issue. Actually a friend said I want to hear your horns, I was like let's go fo a drive. That video I posted does not do those any justice.
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
ScareCrow
Burl
Indiana
BS/Badlands
Andrezzi
Andrezzi
robert
PA
Overkill, but I like it!!!!!!
Not really looking for air horns just something that's a bit louder than our stock horn, Thought maybe full size Ford pick up might be louder, Can anybody confirm if it is ?
Rgill
Vegas
Las Vegas
I have replaced horns in many cars. As long as you can fit it in the bay and the voltage/wiring works you should be good. Horns are easy to replace usually. most horns are operated by a switched 12-volt power feed
dakman
I always like Hella horns. I just wire directly to factory wiring, but I believe using the relay may make them louder. I haven't put any on the bronco. They make different styles and sounds. Supertones on my ST.
IdahoDirtFarmer
Shane
Caldwell, ID
Ram 1500 ordered '23 sport
Funny this thread pops up today. I was just thinking last night about whether or not to pull my old ah-ooga horns out of my Dodge for the bronco or just try and find a new one to put in it.
Mrmike
Syracuse, New York 13219
The '19 Edge Titanium I have had a single horn that was terrible. A member of the Edge forum did a write up on it. The earlier years Edge had twin horns that were much better. It was a plug and play upgrade that several of the members did. Night and day difference and Ford part number. Possibly one of these other Ford horns would bolt right in the BS.
