2.0L MPG Fuel Mileage
Taking the little Bucker up to Yellowstone, stopped north of Denver for the night. From DFW to Amarillo got right about 23.1 doing mostly 78-80. From Amarillo to Denver I got 29.1 doing about the same speeds. Did switch to 88 vs 87 octane as regular up here is only 85 but I don't think that would account for the difference. I noticed a similar difference in mpg last time I was up in elevation over memorial day as well. Just something I figured I'd point out here to see if anyone else has experienced the same thing.
Yup, it's the elevation. Dallas to Amarillo is a slow climb from 500 ft to 3600 ft, but you're in the thicker air nearer sea level for the majority of the trip. From Amarillo to Denver is also a slow climb, but you're in thinner air farther away from sea level. Thinner air means less drag. Less drag means better fuel mileage.
thekingprawn
Dustin
Kingston, Wa
Plus all that damn wind in the panhandle. That can't help.
LastBronco
Indiana
You better get that thing looked at. Mine will run away going down hill and rolls forever on level ground.
I think my 26 mpg average is great considering I’m in the Appalachian mountains. I’m always pulling up some hill or going around a switch back.
No boat anchor here.
Did you make a poor choice for economy in tires ?
Tires are stock Michelin Primacy A/S
Tires stock Miche
stock tire Michelin Primacy A/S 225/60/18 33 lbs
Jumbo1953
...yeah, I'm getting around 21-22/mpg in my First Edition in every day driving. I did get as high as 26 when I went on interstate for vacation but haven't seen anything close to that since...I' also don't use the STOP/START switch and wish FORD had a way of permanently shutting this thing off like my BMW X3 had. It's a pain in my butt and I am sure over time this constant starting and stopping will cause other issues. Those folks saying they are getting 28-30/mpg---I'm calling BullShit...
My 28 mpg on our trip was mostly running 60-80 mph on the highways with very few hills. Ordinarily I get 23-24 mpg with city/highway driving. I normally drive 4-5 mph over the speed limit wherever I am. Likewise I despise the stop/start feature and turn it off before leaving.
endrMinr
'21 Bronco Sport
Just finished a ~2500 mile journey across the Rockies, elevation 1500ft-7400ft, including 80mph interstate. Have a 2.0L first edition with suspension lift and 235/70r17 tires. On the computer, reads over 27mpg for the whole trip, spot checked a few times at the pump and it is pretty close. Im happy :D
thekingprawn
Dustin
Kingston, Wa
Sunday I took my full tank on some forest service roads (slow going with epic potholes, washboard, etc.) then out to the coast for a little fun on the beach. Total distance was about 330 miles with most of it highway (ish...Hwy 101 is quite curvy around the Hood Canal.) Overall mpg was 27.
Your lift that you have ,is it the lift that came with your first edition . I also have a first edition and was wanting to go with 235/70/17 would you advise or not ? Thanks
Ford Bronco Sport 2.0L MPG Fuel Mileage 714C5109-36F6-4188-AA49-5FA5AE10439B
endrMinr
'21 Bronco Sport
It is another inch over factory, from Ford Bronco Lifts. As said elsewhere, its not the height but the wheel well width that limits tire size. A 235/70 will really depend on how square the shoulder is on the tread, because it is that close to rubbing when turning. Since the well liner is felt, rubbing really wont harm anything though. A lot have done 245/65 with no problems, which is wider but slightly smaller diameter.
Outback Texan
MIke
San Antonio, TX
UPDATE... Badlands now at 7200 miles running Premium fuel... mostly very conservative driving in normal mode... averaging 24.5 mpg.
100DB
Rocuo
Spain
Ford Bronco
What is an average cost of your Premium fuel per mile then? I am planning to buy some Premium too but have doubts tbh.
Outback Texan
MIke
San Antonio, TX
...about 14 cents per mile.
100DB
Rocuo
Spain
Ford Bronco
That is insane to be honest...
I guess I will download an app in order to keep track of car expenses as my dad advised. The cost of fuel is raising everyday and I feel anger on the whole situation that is happening nowadays. Sadly, I cannot change anything...
Thank you for your answer, pal
SgtT11B
El Segundo, CA
My BL with the WildPeaks I am averaging 20.7mpg. This is based on my calculation not the computer on the vehicle. That is showing 21.2mpg.
Reactions: Jrl
Mine is 27.7 road 18.3 city . Not bad
Ford Bronco Sport 2.0L MPG Fuel Mileage 569280CD-DA97-4416-AEC2-C6C1BC3331E8
Reactions: Wyo
