25S76 Recall PCM Remedy Now Available
thomasm23
Los Angeles Metro
I checked the Ford app and saw that the status of Recall 25S76 addressing the fuel injector situation is now available. I called my dealer and they confirmed that the PCM software update has been released. The dealer told me that they would need the vehicle for 5-9 hours to complete.
Recall 25S76 is for vehicles equipped with the 1.5L engine produced from 21-24 Bronco Sport models.
This is not a fuel injector replacement. It is only a PCM software update.
Ford will continue to address any fuel injectors found to be leaking at no charge.
Ford Bronco Sport 25S76 Recall PCM Remedy Now Available IMG_0099
rocks
SC
and then there will be a recall on that recall. :D
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
some inconsistency is to be expected
campaign 25S76/25V467
"recall service not available right now"
per ford app/recall
Major Kong
Major
Are you using the latest Ford App?
I am using 6.3 for iOS.
updated android fordpass app
reads the same "not available right now"
most likely will place call to dealer to confirm recall status
newest entry in the ford/app/unreliable file
thomasm23
thomasm23
Los Angeles Metro
In the iOS world, Ford Pass app has been rebranded as Ford app. This has a completely new updated look and feel.
I see that the Android version is still known as Ford Pass app. Is this true? What is the version number of the updated Android app?
Javier
Miami, FL
It's called Ford on Android devices, too and I have 6.3.0 on my phone.
Dbear44
Dave
Harrisburg, PA
I got the same msg about a month ago and took my vehicle in for the recall. The software update only takes about 15 mins. It's the actual injector replacement that takes 5-9hrs. Since mine isn't squirting out fuel on the engine block, the only did the update. After they did the it, the recall still shows as "open" for my vehicle. They said Ford told them it would stay that way, but they didn't know why.
rocks
SC
So you have to wait until they leak?
Dbear44
Dave
Harrisburg, PA
From what I was told, the recall is only for "leaking injectors" and will only be done once. So they will only do the recall, if they are leaking.
Stircrazy
BC, Canada
I had mine done in july when my service was done, I am not sure why they quoted you 5 to 7 hours, maybe because they were just going to do you when they could between other vehicles, the update in mine only took 15 minuits. as of now there still is no parts for the swap of the injectors, or the head or what ever is causing the issue so this is just a stop gap to try prevent more from leaking is what the service manager told me.
Grantorino
Donna
I checked my dealer -no fix yet. They said to wait for the next recall letter.
Stircrazy
BC, Canada
yup, thats what I was getting at. the software flash is just a update to try help them not leak, but not the fix.
SeaJay
Georgia
2023 OBX Sport, Area 51, Hitch, Assist++
My app said I needed the software update, had that done yesterday and now the app tells me I need the injectors replaced. 😜
Haven’t called the dealer yet but it sounds like that isn’t actually a thing they are doing yet?
gvanleer
Graeme
Halifax, NS
So I contacted my dealer this morning about this recall as it is still showing 'Attention needed' on the app. This was their reply.
"The initial fix didn't work and we are awaiting updated software. It will still need to be completed, but only once we have the update. you will receive an updated letter from Ford Canada "
So basically, hurry up and wait...
