Can’t reset oil change alarm - not happy
Backpackster
Jeff
Ottawa Ontario
2021 Ford Bronco
After 8000km and 6 months I was getting the oil change request alarm. So I dutifully got it done (mr lube - wasn’t cheap but they were all curious about the car). Now I cannot reset the alarm. There is no menu item. On a you tube video one commenter stated that it is a secret sequence that can only be performed by Ford. If so I’m pissed. Any idea out there?
Jess1
SE Texas
F150
Don't have menu button on far right of steering wheel?
Huh.
Jess1
SE Texas
F150
Can't scroll down with center button on the right side?
Backpackster
Backpackster
Jeff
Ottawa Ontario
2021 Ford Bronco
All I got
Jess1
SE Texas
F150
Canada then? Try the old Ford method - ignition on (NOT engine), press and hold gas and brake pedals for a few seconds...?
Backpackster
Backpackster
Jeff
Ottawa Ontario
2021 Ford Bronco
I tried that once before but never found a menu that way. Never had a detailed vid through. I’ll go try again now! Thanks.
Wow. Realized my problem. I didn’t know you could turn the ignition on without starting the engine by pressing the start button without touching the brake. Kind of obvious now. Once I did that the full menu appeared. Thank you. I’m not mad at ford again.?
Warpious
www.floracreekplace.com
Answers in these forums make me happy
Backpackster
Backpackster
Jeff
Ottawa Ontario
2021 Ford Bronco
To put it more simply, do this (OP seems to have figured it out, but for anyone else stumbling upon this thread):
If you're starting off at your Trip odometer screen, or digital speedometer, etc, scroll up/down on the right side of the steering wheel until you get to the render (graphic) of a Bronco Sport.
Hit the menu button (three lines) on the wheel.
Scroll down to Oil Life, hit OK
Hold OK to reset - it'll tell you on-screen when this is done.
Well yes but the key fact is to be in the full idc menu. This is only entered by pushing the start button without touching the brake. The menus after engine start do not contain the oil reset and other goodies.
Reactions: MJE
