Factory mats sliding around on plastic floor - anyone have luck fixing?
Orin
Indiana
I would get rid of them and get the rubber mats. My bronco came with both carpet mats and rubber mats I dunno why. But the rubber ones are superior to the cheap carpet mats.
Slingy
Ben
North Of Boston
What's the part # on those? Back seat floor too? Those are nice, just going to order some and be done with it.
If you get the BS specific rubber mats (front and rear) from Ford, the carpet mats will fit right into them and not slide around so much. I like the look of the carpets but they easily get destroyed in the Winter. I intend to put them back in when the weather gets nice so for now they reside under the cargo floor with the spare tire.
Unless something has changed, the factory carpeted mats for the Badlands snap into place on top of the rubber flooring for the driver and passenger sides, they don't slide around.
When I offroad my Badlands, I have to un-snap them, then throw them in the back so they don't get full of dirt.
Long Beach, CA
'22 Bronco Sport, '20 Jeep Gladiator, '99 SLK230
bbbronco_in_LBC
As some others have said, are you sure you have the floor mats that come with the Badlands?
My front carpeted mats snap onto the rubber flooring, the rears don't snap down, but they don't/haven't moved an objectionable amount.
Not sure. It came with the same standard mats as the Big Bend - nothing special about them that indicates Badlands version. Driver's map snaps into place on two pegs, passenger has one peg, rear just slide around wherever they like.
The rubber mats are the mats to get. The carpet mats are pretty useless without the rubber ones, but if you happen to have both (best value option IMO) then the carpet ones fit right into the rubber ones and that keeps them from sliding around in the rear.
Warpious
www.floracreekplace.com
Order them through the Ford accessories site and they have 15% off right now with the promocode at checkout. You have to be logged in for it to work. Just ordered ours this morning
Ddodd717
Dodf
2021 bronco sport
I have a problem with the plastic floor in my Badlands: The floor mats slide all over the place - same with cargo. What solutions have you found to fix this? 3M Velcro does not stick to this stuff. Ready to toss the factory mats for some rubber ones.
Buy weather tech. That's what I did
NPeartrip
Rochester, NY
2022 BS
I went with Rough Country. 160 and they fit like a glove.
Long Beach, CA
Got the molded rubber ones from Ford Accessories. They're nice! Just wish there was a way to attach the carpet mats since the new ones snap into the front leaving the carpets loose (but far less slippery than the floor and acceptable). I really like how the back mats cover the center hump and have a logo - makes it appear more finished.
Polish ghost
2018 ford escape
you could try a bead of silicone caulk. try one bead on the underside of the carpet for a trial. let it cure completely before putting it back in the Bronco.
I've done that on carpet runners at home, keeps them from slipping around but they peel right up for repositioning.
That will leave a order every time you drive
