Big Tires for BS Badlands
Watch the begging of this video, he put 255 on it without a lift on big bend. 55 second in.
If you would, what is total height of tire compared to my 235 65 17 , 29 3/4 is what my 235 are . Thanks great information and video .
Ford Bronco Sport Big Tires for BS Badlands 8D395C1E-657B-4914-8108-BFB02DC3060A
They are the tires in the picture.
Ford was quoted in a Car&Driver/Motor Trend article saying the largest tire you can fit on a Badlands or First Edition is a 30.5" tire. 245/65/17 are 29.5", so no need to modify anything if you go with that size.
Do you happen to have a link to that article?
rdc17
VA
Bronco Sport Badlands
DISCOLEG
Thanks, appreciate your time in gathering information . Looks like that 255 might be a bit of a stretch. For a first edition .
Ford Bronco Sport Big Tires for BS Badlands 560563D4-3E7E-4848-A693-5E0D7FEF6A9C
255 without a lift definitely will rub off-road. I'm going to put 245/65/17 KO2s on mine at some point.
Bamsi
Bamsi
Puerto Rico ??
I'm interpreting that to mean a lift will allow 31" tires. I didn't think the constraint was height, but rather width of the wheel well common to the pinch welds. I'm suspicious.....
I agree with you Tburner. It is stated clearly the BS BL will fit a tire up to 30.5 inches without clearing problems, but with the proper lift will accomodate a 31 incher.
tburner
Troy
DFW, TX
Be the trail-blazer, @Bamsi! Get a lift and try to stuff some 31s in there!
CallMeBill
2022 Carbonized Grey Badlands
Just got my 22 Badlands and have been researching new tire/rims combos. Reading thru this post makes me wonder that if I go with the 1.25" HRG lift kit would I be able to go with 265/65/17 tires?
From what tire size comparison site says the Diameter would be 30.6" so may work right? Of course tire revs would make the speed to be off at 70 mph to actual of 73.9 mph.
Bluebaru
DON'T DO IT! Clearance issues are more than just tire diameter. In your case a 265/65/17, in combination with the increased diameter you're adding a significant increase in width. A terrible combination.
If you want to push the limit get a 245/70/17 and expect to need to cut back the fender liner and trim the pinch weld. Now, if you want to go a little wider and don't mind the same mods, you might want to try a 255/65/17
tburner
Troy
DFW, TX
We're all itching to see what the tallest tire is that we can stuff in the wheel well. Take one for the team and find out! But I agree with @Bluebaru:
Adding width will increase interference when turning the wheels.
