VirtualJMills
Jason
California, US
… has anyone tried Torque Pro (Android) or OBD Fusion (Apple) apps to see info is available thru the OBDII port? Wondering if oil pressure, boost, transmission temps, may be available. I used the attached in my F150 just playing around.
Have not tried those two specific apps. Using OBDLink-MX+ with FORScan on iOS personally.
Boost pressure is not •directly• available, but inferrable from other data (I discussed in another thread).
PTU fluid temperature is available, I •think• transmission fluid temperature is as well. Will make a note of what you have displayed in your screenshot and do a quick comparison when I get a chance.
Using OBDLink-MX+ with FORScan Lite on iOS:
Ambient Air Temperature (outside) is available via PCM.AAT
Intake Air Temperature is available via PCM.IAT, PCM.IAT11 (Bank 1 Sensor 1), PCM.IAT12 (Bank 1 Sensor 2)
Air-Fuel Mixture (Lambda) is available via PCM.EQRAT11 (Bank 1 Sensor 1), PCM.EQRAT11_CMD (same, but commanded value target)
Engine Coolant Temperature is available via PCM.ECT
Catalytic Converter Temperature is available via PCM.CATTEMP11 (Bank 1 Sensor 1)
PTU (equivalent to transfer-case in function) fluid temperature is available via AWD.PTU_SUMP_TEMP
Transmission (front transaxle) fluid temperature is unavailable from what I can find so far
EGR Temperature (not exhaust-gas temperature) is available via PCM.EGRT_B
Ambient barometric absolute pressure is available via PCM.BARO
Intake Manifold Absolute Pressure is available via PCM.MAP (PCM.MAP minus PCM.BARO when greater than zero indicates definite turbo boost, when negative or zero turbo boost output is either negligible or lagging)
Note: Some data such as AAT is available via multiple upstream module sources, but I'm fairly certain they're really the same underlying sensor.
ScareCrow
Burl
Indiana
BS/Badlands
SunZmSpark
I think I finally found the perfect Plasti Dip color match for the front and rear lettering. The stock lettering is white and I originally painted them black (I don't like the vinyl overlays since they leave a white border) but thought it was too dark. I wanted to match the color of the front grill (and the wheels) but couldn't find anything close enough. I decided to try Gun Metal Gray (https://tinyurl.com/vwvzkzn5) with the Plasti Dip Metalizer (https://tinyurl.com/kcrabats) as an overlay and it came out perfect.
Ford Bronco Sport What did you do TO your Bronco Sport today? BS_F_GL_2
Ford Bronco Sport What did you do TO your Bronco Sport today? BS_F_GL_2C
Ford Bronco Sport What did you do TO your Bronco Sport today? BS_R_GL_TH
younglefthander
Jack
Orlando
Bronco Sport / Maverick
Wasn’t what I did to the BS today more as what we did today. Started a 3 day trip to Sapphire NC. Ride from Florida was great.
Ford Bronco Sport What did you do TO your Bronco Sport today? 056DFA02-2CC7-4CA8-8311-527A265CE9A1
Ford Bronco Sport What did you do TO your Bronco Sport today? F4AB1E01-4FC7-4BBD-A9FF-DFFFEE169817
Ford Bronco Sport What did you do TO your Bronco Sport today? F199026F-967F-45FA-AA14-4CB0D38BB48A
Ford Bronco Sport What did you do TO your Bronco Sport today? 43C8F2F9-A29F-4A83-9FCE-CB127306A7E1
Wasn’t expecting to go off road but when in the big hills of NC it’s almost a given. Granted the terrain wasn’t Black Bear Pass but still the off road was definitely gravely, wet, and steep some steep hills. BIg Bend performance was spot on. Loving the BS. Looking forward to seeing what tomorrow brings.
Ford Bronco Sport What did you do TO your Bronco Sport today? 551C7F29-F5A3-4F50-8C0D-3E1C0609D34F
Ford Bronco Sport What did you do TO your Bronco Sport today? 0C0304AD-7FE9-4A95-8F65-01CB1029DC68
Ford Bronco Sport What did you do TO your Bronco Sport today? 0D9C848F-FF69-432C-8F7A-9814A5B2B86E
Ford Bronco Sport What did you do TO your Bronco Sport today? A3590E6A-CD35-4896-AFF4-31855F2A4DCF
Ford Bronco Sport What did you do TO your Bronco Sport today? C402E951-83A0-4549-9FDF-D242ABEA27C1
Ford Bronco Sport What did you do TO your Bronco Sport today? 8C3A3A02-047A-4075-9FF0-91EDE096DA01
Ford Bronco Sport What did you do TO your Bronco Sport today? 960C7536-9685-4456-AD29-1890E8C0D9B1
Ford Bronco Sport What did you do TO your Bronco Sport today? 5F3B392C-89C8-4619-BEC6-18F0F91A78F2
Ford Bronco Sport What did you do TO your Bronco Sport today? E266658C-FDCB-4381-A73B-669A3B086ADB
Ford Bronco Sport What did you do TO your Bronco Sport today? D7728925-7AE6-4C46-9289-90FECF81DA34
Ford Bronco Sport What did you do TO your Bronco Sport today? 46034A78-E0B7-4221-B011-38890994266A
Deleted User 772562
Maria
NJ
2021 Bronco Sport Outer Banks, 2021 Ranger Tremor
Got a key fob cover. I always have several things in my pocket and like everything to be protecte.
Ford Bronco Sport What did you do TO your Bronco Sport today? image
I saw something like this on Etsy! Looks great! Love the color too.
Deleted User 772562
Maria
NJ
I keep putting it in my cart but never pull the trigger, I like that it says bronco on the fob a little more
Me too! I saved it under my favorites, but never committed yet. I like how the fob says Bronco too, but I’m always dropping it if it’s not in my bag. ?
https://etsy.me/3yYQkLz
