MoFoCo
Mayor's Income, TN
Microwave is going to be tricky, given the rated output of the on-board inverter.
Adding a standalone LiFePO4 based inverter+battery bank feeding the microwave oven would be more viable, letting the bank (re)charge off the vehicle on-board source (either 12VDC or 120 VAC/400W).
Yes, it’s kind of a silly idea. Would probably go with a propane stove instead. To run a microwave would require several thousand in gear, including Li batteries, B-to-B charger, inverter, etc. Plus $800+ for a fridge. That same money buys a lot of burritos and sandwiches.
ctrabbit25
ctrabbit25
Carlos
Austin, tx
I do have a jackery to run a dometic fridge and a propane camp stove for cooking that slides out under the sink/cutting board
Idontknow
Will
MN
Cross trek and grand caravan
That looks great! What’s your plans for finishing touches paint and the stick on edging to cover the exposed plywood?
ctrabbit25
ctrabbit25
Carlos
Austin, tx
It's going to be painted with a black satin polyshade paint and the edge covered with neoprene rubber trim. The top will have countertop laminate. I will post update photos
Gunther706
Maryland
Love the build! I like the way your roof rack is looking too, which crossbars are those?
VirtualJMills
Jason
California, US
Update:
Here are updated photos of the finished build just painting left to do.
Ford Bronco Sport Bronco Sport camp kitchen build PXL_20211024_203153371~2
Ford Bronco Sport Bronco Sport camp kitchen build PXL_20211024_201247875
You might want to put some thermal insulation / fireproofing on the areas facing towards the stove when deployed in operational configuration. Something like grade 1401 millboard to reduce thermal transfer would work.
R. Bird
Marvin Martian
Mars, now Ohio
Area 51 OB+OB, 360+, Tow Pkg. (2021)
MoFoCo
Mayor's Income, TN
I see you have it held down with a ratchet strap, any further thoughts on how to keep the box in place? I’m thinking of doing something similar but about half as wide. Without a tie-down point in the middle, a strap won’t do much.
VirtualJMills
Jason
California, US
Ideally something like cam-locks or lever-locks to the four-corner cargo tie-points would keep it anchored firmly. Skip all the flex and stretch of straps.
TnyM
Tony
Seattle
'77 Chevy c10, '22 Bronco Sport BL
Damn... That looks really nice. Nice job.
That took some ingenuity right there! Any chance you might offer plans?
Benanza
Ben
NJ
This is such an amazing diy setup. It reminds me of a lot of the construction tool setups I've seen on vans and SUVs. Great job! Only thing I'd consider doing, if not already done, is get a hitch tire carrier so I wouldn't have to worry about getting to the spare when it's packed.
