Wish Back Seat & Cargo Area Lines Up To Lay Flat
Is there a difference other than the logo?
I bought the optional mat, so at the risk of defending it...
It's slightly easier to remove, and much easier to clean than that pressboard cover. I wouldn't be afraid to pressure wash it if I had to. It's also a more pliable rubber than the sort of plastic-y coated cover so depending on the thing you load, it slides a little less. A lot of the accessories are underwhelming IMO, the mat is one thing I am still happy with.
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
Sweet. I ordered one so glad I did
Martinjv71
Martin
Chicago, IL
2024 BadLands
Since I posted, I saw pictures of someone else who’s lays flat. So it looks like it can be done. But how?
If you look at the ledge inches above on the sidewall above the floor liner there is a ledge to set in to to line it up. There are 2 positions...........
Shan742098
Shannan
RAv 4
If you take the cover and lift it out and slide it onto the little tracks that I circled it lifts it up even for you...
Ford Bronco Sport Wish Back Seat & Cargo Area Lines Up To Lay Flat 1cover
I am hopefully ordering one of these bad boys soon... When you move the platform up to make it more level is it sturdy to sleep on?? We often do long trips to Florida from Wyoming and we make a bed in the back and sleep back there... Is it sturdy?
VirtualJMills
Jason
California, US
You'll need to place something on top of the spare tire to make up for the vertical gap, if you don't have the full sized spare, that's what the upper notch is for.
SportWest
22 Bronco Sport Badlands
Probably not. You'll need a full-size spare or something for the platform to rest on when you slide it into the upper notch. Otherwise, the platform has a tendency to slide off the 'lip' near the hatch and fall down, so the platform slopes down from the upper notch to below the hatch deck.
Monkey
Those with the Badlands or full-size spare, the rear floor is only usable at the higher setting so it’s flat. There is a bit of an up-slope to the rear seats then they’re folded down, but flat for all intents and purposes. The rubberized floor and seat back protectors (not sure which trims those are included with) are nice. The cargo mat isn’t really necessary due to the rubberized floor, but I’ve found It handy since it catches a lot of dirt and then easy to remove and hose off.
Adanac
Ontario, Canada
That I don't know as I am awaiting mine still...Nov 17th
MoFoCo
Mayor's Income, TN
Darn, I was kind of excited about gaining a couple inches of vertical space. Didn’t know there were multiple positions for the deck.
MonkeyKing1969
Linc
Nantucket
Ford Escape 2009
If there is one wish for the 2023 model year, it would be a totally flat extended cargo area. Many people camp/sleep in the cargo area, so a flat cargo area with the lowest cargo floor possible is a must. I would ditch the 'lift-up' under seat stoage areas to re-engeer the back seats to fold so that the rear cargo is flat. It is supposed to be 76" with the seats down, so if was 76" flat a person 5' 11" can lay downwith their feet touching the back - not ideal but doable.
A Ford Bronco Sport XL that was four inchs longer in the cargo area would be good too... ;-)
DMEARC
2019 Mustang, 2021 BS OB
I know this is a late reply, but yes the platform is sturdy enough to sleep on when it’s been moved to the higher (level) position. We’ve done it many times. There’s no need fo any other modification.
