Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
My first "mod" to my Bronco Sport:
Center console safe -
Ford Bronco Sport What did you do TO your Bronco Sport today? p928dzBmY4Tlwoh?width=660&height=495&cropmode=none
Organizer for the back -
Ford Bronco Sport What did you do TO your Bronco Sport today? Wr06gewlQIr7tDQ?width=660&height=495&cropmode=none
New shoes (Yokohama Geolandar A/T G015 235/60R18) -
Ford Bronco Sport What did you do TO your Bronco Sport today? 04ZZPAudCaSb8Rt?width=660&height=495&cropmode=none
And the MOST important "mod" -
Ford Bronco Sport What did you do TO your Bronco Sport today? VuMdPHdlCBOjxpx?width=660&height=495&cropmode=none
Do you like the safe?
Benanza
Ben
NJ
Let's hear about the safe, it's the one item I always keep looking at. First is it worth it, does it seem secure enough with just a couple screws in the plastic? Easy to get in and out of say if I was rushing? Is there enough space for glasses case on top with the armrest closed? Any reason you chose dial over the key? Sorry I'm being nosey, it's the first time I've seen it on here besides the backseat version for BL
Mike_L
Guam
Installed the Ford Off Road Crossbars. Why these don't come standard is beyond me.
Ford Bronco Sport What did you do TO your Bronco Sport today? Mikan Crossbars Overhead
Benanza
Ben
NJ
Cause so many people have already got their setup on another car. Most of the Yakima and Thule bars have interchangeable towers to attach to other vehicles if the rails are different. Some people prefer an overhanging bar and some prefer a basket or platform. Some want a bar like you have, but others want a modern bar with a T track that gives them more attachment and configuration possibilities.
M1Tanker
Tony
WA State
yep, there is a nut in a raised bracket under the jack. The rod has a molded plastic thing on it that you use to scew the rod in and hold the jack in place. No tools needed.
Awesome. Just picked up the longer rod and will put it in this weekend.
Spartan007
Jacksonville
So far just cosmetic upgrades:
Black Rhino rims
Bf Goodrich KO2s
Debadge “Sport” (hated how crammed it looked)
20% tint
Black/grey Ford Badge overlay
Metallic Silver Front Bronco overlay
Ford Bronco Sport What did you do TO your Bronco Sport today? FC91FBF0-2860-42B4-AFC4-0B09A5055E20
Ford Bronco Sport What did you do TO your Bronco Sport today? 78FCBDB8-9443-47C7-8270-1395264E3151
Ford Bronco Sport What did you do TO your Bronco Sport today? 85B7F66C-A00C-40B6-957B-90826421324D
Ford Bronco Sport What did you do TO your Bronco Sport today? 37DDBB26-09B1-4146-870B-424FECDED5FF
Ford Bronco Sport What did you do TO your Bronco Sport today? FF9BD6E3-FDEA-4917-A4CD-2F1C5394FFD6
Ford Bronco Sport What did you do TO your Bronco Sport today? 7CF0ED34-33A7-417F-A233-631EDD261FC0
What size are your rims? And are they the black rhino boxer?
jazzdab
Thom
Raleigh, NC
The BS ConsoleVault is somewhat flimsier than I'd like. It would not take a huge effort to pry off the locking mechanism from the lid - which would be much easier than yanking the whole safe out of the console. It certainly feels safer than relying on a locking plastic glove box. Even a safe that bolts to your seat can be removed with enough time and effort. I went with the 3 number combination for ease of access and no reliance on keys. The wheels are a bit stiff to manipulate; hopefully they will break in. There is a small amount of space on top of the safe with the console lid closed - probably enough for a pair of glasses. Just be aware anything on top will slide all around. I'm not sure it is any more secure than a LifePod 2.0 cabled to my seat, but it does integrate well into the vehicle.
Overall, I like the safe but I wish they had made a channel to allow you to use the USB ports. Even if I had to use a tool to get the cable in, I'd at least like that option. Or even make the ports accessible from INSIDE the safe.
RRD
Toby
PNW - Puget Sound Area
2022 Bronco Sport Badlands - Area 51 "Bad Alien"
Let's hear about the safe, it's the one .........
This is the same safe you get from Console Vault (The company that I have used for every safe I have in all my vehicles) just branded by Ford (So if you want to ditch the Ford Emblem you could save directly from Console Vault maybe, I did not look.
It opens reverse direction then all my other vaults so that did get some use to but I love the 4 digit combo as it is a bit more secure then 3 and does not require you to use a key. I have a habit to UNLOCK it when I enter the vehicle and LOCK it prior to exiting.. as it secures my vehicle self defense firearm.
ANY vault you have in your vehicle is only a deterrence to a criminal HOWEVER, MOST break-ins are "opportunity" strikes and thus they do not want to sit there and find a way in while the alarm goes off. I never park my vehicle "Alone" it is always in higher traffic areas or my property so someone will hear the alarm. If they were specifically after your vault then it would not matter which one you have.
It uses 4 self tapping screws to secure it into the plastic sides of the center console, this is how all of them have worked from Console Vault and never had issue in over a decade with any of them.
The quality is on par with all other Console Vault brands and other brands I have used, it is a deterrent type of secure storage remember.
I can say I have had a vehicle broke into and have had the contents of the vault still intact after the break-in and the vault was discovered.
Hope this answers your questions!
Benanza
Ben
NJ
@RRD & @jazzdab, Thank you both for your honest detailed answers. It seems that the only way it's not safe is if my alarm doesn't go off giving them the time to access it without drawing attention. Definitely sounds like its still worth it if you want to park and not worry.
jazzdab
Thom
Raleigh, NC
I bought directly from ConsoleVault and it came branded with the Ford emblem. They’re an official partner now. It is cheaper to order direct - especially if you can find a coupon code.
Reactions: RRD
