Buzzing from driver side door while speakers in use
SilverVVolf
Rad
OK
Isn't hard to hear. I noticed during this song that it was hitting it perfectly to be able to hear what I'm talking about. Really noticeable if there's no music and it's just talking. Doesn't sound like it's a blown speaker. Probably just something loose? These speakers are going to get replaced eventually with aftermarket.
Anyone else have this buzzing only heard when playing music on certain frequencies like heavy bass and when people are just talking? It's been like this since day one, just only started to bother me.
jazzdab
Thom
Raleigh, NC
Dynamat.
vxarctic
Might be worth popping off the panel to take a look. Someone on the forums previously was swapping out their speakers for after market and found out that one the speakers wasn't even plugged in.
SilverVVolf
SilverVVolf
Rad
OK
Wow. I haven't seen that thread yet. That definitely sounds like the plan, just nervous about doing it myself without step by step instructions.
vxarctic
brockdog12
NTX
My passenger side front door rattles on certain songs.
Chickpea
Amanda
GTA
Is it pretty much the same spot too? Closer to the speaker the more defined the noise becomes?
Just picked my Outer Banks on Friday and yesterday I noticed the driver speaker buzzing with some low bass music even at low volume. Blown already?
Benanza
Ben
NJ
Usually the first thing to check is the map holder.
fourthgear
florida
Something may be loose & vibrating under certain conditions or frequencies . Also could be a bad speaker , if cracked they will buzz.
SilverVVolf
SilverVVolf
Rad
OK
Wouldn't they buzz at ANY volume? Not just cranked up? I'm thinking it's something loose in the door.
fourthgear
florida
I had a rear blown speaker in m y F150 & you wouldn't know it till the sound was cranked up . Then the distortion was crazy the more you turned it up . I also believe its some thing loose .
SWUKU
GB
KY
I have a similar vibration sound issue at certain ranges as well.
Driver side door speaker is buzzy & distorted on select lower range songs at reasonable volume levels.
And I don't listen to heavy or thumping bass - mostly old blues music.
It's not present all the time, like this video clip. But it Very Disappointing, b/c I have the "premium" B&O sound system.
