Baby Bro Blackout Stage 1
BabyBro
Ralph
Stage 1 in blacking out my Baby Bro. Very simple and minor enhancement in getting my blackout project started. Plasti dipped “Sport” to really bring emphasis to the BRONCO name. Blacked out the Ford emblem, because it’s aesthetically pleasing to my eyes!
Up next is blacked out window tinting!
Ford Bronco Sport Baby Bro Blackout Stage 1 0E6A6128-0D3F-4EFB-B76C-39BCE094FE56
Ford Bronco Sport Baby Bro Blackout Stage 1 E86B1657-6856-4EBF-9396-A5287AA864C9
zjc26138
Zach
Steubenville, Ohio
www.astrobin.com
Man those plastic dip letters look great!
Is plastic dip difficult to use? I would like to do the rear letters on my BS.
aryus
Sin City
2021 Bronco Sport Big Bend
It's very easy. Mask off the area well as there will be overspray (which comes off pretty easy with car cleaners/rubbing alcohol). Clean all surfaces diligently. Use cotton swabs the get into the edges of the letters. Lay down several coats from several angles with about a half hour between each coat. I think I did 5-6. Then peel away the masking and dried plastidip between the letters. It will tear along the gaps between the letters and the car itself. You may need to use some toothpicks to pull it away from the smaller letters and the insides of the larger ones. Just take your time. Lots of videos on youtube if you want to see the process.
Hope this helps.
TexasJDub
Jerry
Looks much better now. How many coats did you apply?
I applied 5 coats. First spray is super light in spurts just to coat enough for the next coat. Light coats each time so that it doesn't pool or clump. I would let it dry at minimum 15 to 30 min in between. Used a toothpick to get to the hard to peel areas between letters or within a letter. Just make sure you take the time to tape all around to avoid over sprays and subsequent cleanup.
SilverVVolf
Rad
OK
Not difficult to use. I would recommend Hyperdip from dipyourcar.com tho. Much smoother finish, higher quality, longer lasting. Take a look at these pictures so you can compare the difference. I originally did my pony badge in plastidip, but then discovered the superior Hyperdip. Buy the emblem package. Has everything you need.
Ford Bronco Sport Baby Bro Blackout Stage 1 IMG_20210725_104540
Ford Bronco Sport Baby Bro Blackout Stage 1 IMG_20210716_230234
Ford Bronco Sport Baby Bro Blackout Stage 1 IMG_20210618_090207
Ford Bronco Sport Baby Bro Blackout Stage 1 20210618_064448
Ford Bronco Sport Baby Bro Blackout Stage 1 20210618_064437
Ford Bronco Sport Baby Bro Blackout Stage 1 20210530_220008
Ford Bronco Sport Baby Bro Blackout Stage 1 20210506_075127
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
2023 Ford Bronco Sport
Great job with the masking and painting. I gotta say, it looks like a Bronco instead of a Bronco Sport (when doing the black on black). You only need the spare tire carrier, and you'd have a decent clone from the back end side.
Looks great.
