Bronco Sport Badlands dies crossing 20" of Water
Johnperrion
Wasatch Mountains, Utah
I'll go do it right now good sir.
If you click the link and it doesn't work. erase the #sign and everything after it.. I have no clue why the additional crap is getting added when I post my Imgur albums.
Big Brody
Big Brody
Todd
Denver
Thank you sir!!
broncobuster2550
Something slow
FYI that isn't the main ECU harness. The ECU and main connection are on the other side of that metal plate/bracket.
Big Brody
Big Brody
Todd
Denver
Som
Some silicone fusion tape around the conductors may go a long way in making that connector better.
So driving our Bronco Sports through rivers,? Take that off the list of things to try.....
Johnperrion
Yeah I was just informed of that by someone else as well. D'oh. I am updating my post.
Johnperrion
***EDIT***
Thank you to several members who have pointed out that was NOT the ECU, it is mearly a junction box. So I haven't moved the ECU at all.
The actual ECU is behind that metal plate and IS protected by a combination of a plastic compartment and then the wheel well liner.
Ford Bronco Sport Bronco Sport Badlands dies crossing 20" of Water {filename}
Thank you to the people who were kind enough to reach out and correct me without being a dick about it. I am not an expert by any means and am only trying to provide information to be helpful. It is very likely that things I say/do will be incorrect or inaccurate, but not purposefully.
I'm just a human and I'm learning.
Ok so its that other thing. But it still gets dunked under water at 23 inches right?
broncobuster2550
Something slow
Right, those connections are generally safe from splash, but would be submerged during a slow water wade event. I'm still surprised this ECU got fried, as all those connections should be sealed against water intrusion. Ford did test for this sort of thing.
GT1
bmw x1, 1965 mustang GT convert
For people like me wondering if you have to remove the bumper to see the connector - just look at the opening on the drivers side where the tow hook it. Easily seen and pretty much exposed to anything coming in the hook opening. One can only hope those connectors are extremely well sealed as it is not an ideal place to put a major electrical connection. Even washing the car will get this connector very wet when hosing off the bumper.
To johnperrion, nice work on showing everyone the issues. Would be interesting to open the connector when ECU is replaced to see if water got into the connector. Looking at the location of the connector and exposure to outside I would not be surprised to see it shorted out which caused to ECU failure.
Big Brody
Big Brody
Todd
Denver
Thanks for the additional pictures! I am going to ask the dealer for pictures so we can compare.
Big Brody
Big Brody
Todd
Denver
It is going to be covered under warranty. So far they are replacing the MCU (main computer unit?) and the engine harness. Amazingly they found parts. Now I have to wait to see if anything else got toasted once MCU and harness are replaced. They are chalking it up to the connector not being sealed. You may all want to have the dealer take a look at your own MCUs to ensure the connector is correct before getting caught like I did.
Chase65
Chase
Kansas
'21 BSFE, '21 BSOBX, '12 F150 FX4, '94 Explorer, '93 YJ
Someone needs to figure out a good relocation for this. Wonder why Ford thought inside the wheel well was a good place for the ECU? Even if it’s sealed water tight, I don’t like the idea of it potentially being underwater at times. They did this but left that huge open space inside the fender on the drivers side, would’ve been high and dry there it seems.
