Is the BS 1.5L EcoBoost the same 1.5L that have had coolant leak issues?
BaseOrBust
2017 Ford Focus
Doesn't seem to be the same. The 1.6 & 1.5 Liter engines in this article were in-line 4 cylinders, offered from 2013-2019 respectively in the Escape. Pretty sure these engines are now defunct. The 1.5 liter Dragon ecoboost engine in the Bronco Sport is a 3 cylinder engine.
Excape
Reg
TN
That is correct, those engines were four cylinders and this is the replacement. The problem with the coolant leakage on the four cylinders shouldn't affect the 1.5 3-cylinder Dragon.
My primary concern for the 3-cylinder is the BIO timing belt. Hopefully, it will prove more reliable than their earlier attempt ten years ago (Ford Europe).
I found the service Interval for this new 'Wet Belt' It's 150,000 miles. I'll trade mine well before 100k miles on a new model.
Probably a Hybrid or full EV I'd think :D
MizzouMan_2000
Chris
Central Illinois
2017 C-Max Energi, 2018 Silverado LT
Awesome. Thanks for the feedback. Although jumping on the first year of a new model of redesign mashed be nervous, I definitely don't want to jump into something with a KNOWN issue (i.e. Ford focus transmission).
kmac1036
Midwest
F-150
If you're worried at all, pick up a ford protect plan from floodfordesp.com
I'm planning on doing that for the one we're signing papers on this week. This one will be the 3rd EcoBoost in the household. 100k on a 2L Fusion & 75k on a 3.5L F150. No complaints here.
Gogoggansgo
Steven
Dyer
Fiesta st
For those that don’t know the 411 with this engine in the bronco sport. First and foremost the previous gEN 1.6/1.5 4 cylinder used in everything from the fusion to the fiesta st is a great engine but it’s a good example of what happens when you downsize too aggressively. The fiesta st is a great example I’m running a hybrid turbo with single port injection making 350whp on e40 and beat it like it doesn’t know. You wouldn’t be able to do this in the other variants because it’s over stressed in the escape & fusion. Small engine with an open deck blocks and a small turbo, causes all sorts of block to cylinder head movement. This is why the new 1.5 3 cylinder is truly a next gEN engine, semi clocked deck block, both direct/ port injection, timing chain vs belt. And it’s also a twin scroll turbo meaning it’ll support some serious power with a tune
remember this engine in the bronco sport and new escape is the same in the MK8 fiesta st in the euro markets the main difference is the tuning 87 “regular gas” vs 98 Ron for euro markets
aka regular vs premium, this is why the rating is much lower and why i wouldn’t recommend premium unless you’re running a tune, high elevation or towing
Gogoggansgo
Steven
Dyer
Fiesta st
The dragon engine has no timing belt
Huntyeraws
Nick
Rochester, NY
2021 Ford BS BB
WoodmanMN
Woody
WAAAAAAAAAAAY Up North
Well, the video does specifically state "camshaft chains" and the graphic shows chains on the timing set. I'd say it's a timing chain based on that.
