Accessory Ready - Tray on Dash 2025
wireman
Murrieta
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 IMG_4287
I connected the bulletpount mounting solutions 25 bronco sport package. Connected right to the two mounting bolts. 😊 got a VERY solid phone holder and a GoPro mount connected.
Do you use a Go-Pro and are you using the USB-C ports for a power source?
wireman
Murrieta
I sure am. Using the dashboard USB-C ports to power, my phone and the GoPro
Thanks. That was my concern, can the USB-C ports can handle the needed power requirements of a dashcam. Obviously all dashcams have different power specs.
It would be nice to know what the power output is from the ports.
I don't intend to use any phone mount.
Frenchy906
2025 Bronco Sport Badlands
There’s adequate power there for anything that needs power. 😊
2025 Badlands Sasquatch
Power for Go-Pro devices vary, should be able to look up the specific Go-Pro model # to see its power requirements
Some examples:
Go-Pro Minimum Power Input: 5V / 1A–2A for older models (HERO7 and earlier)
Recommended Power Input: 5V / 2.4A–3A for modern models (HERO8 to HERO13)
“It would be nice to know what the power output is from the Bronco Sport ports”
That’s easy to measure using: Klein Tools ET920 USB Power Meter, USB-A and USB-C Digital Meter for Voltage, Current, Capacity, Energy and Resistance
I still have not found a spec from Ford for the power that the USB-C port in the ‘25-‘26 accessory tray can provide
For my 2022, I measured the Center console USB-C Port: 5V/3A which is 15W using a high power USB Cable (USB Cables as well as the end device being powered influence the output power put out by the USB Port - easy to measure with the Klein tool)
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 IMG_6593
Apparently the ROVE R2-4K camera can be powered from the USB-C port in the ‘25-‘26 accessory tray
Not entirely sure but this camera’s USB-C power requirement might be: ~5V @~1.5A (TBD). I still have not found a spec from Ford for the power that particular port can supply.
Also: a hardware kit can be purchased from ROVE to supply power for some amount of recording when the vehicle is turned off
Another owner posted these pics (the added wording is mine)
https://www.rovedashcam.com/products/rove-r2-4k-car-dashcam
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 IMG_6585
Here is a pic showing the camera view to the front … some amount of the hood is seen in this pic
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 IMG_6595
wireman
Murrieta
There are many dashcams that exceed the power output from the USB-C port in the ‘25-‘26 accessory tray - they won’t work
Before moving forward, I'm going to have to decide which dashcam I'm going to buy.
Then decide which power source is capable, dash tray, another fused source, tap into the rearview mirror power source for a window mount or ???
Typically have to tap into 2 fused sources, one that’s on with ignition (like USB or the rearview mirror power source) and one that’s always 12V (hot) - there are optional hardware kit(s) to tap into these sources
