2026 Badlands Adaptive Cruise Control question
NMBroncoSport
PJ
The wife just got a 26 Badlands with Badlands Tech Package. Question on the Adaptive Cruise Control (probably applies to all Fords?).
On my Toyota, the adaptive cruise control keeps me at a distance and will automatically brake when I get too close to car in front or if car in front in slowing, regardless of whether the ADC is "active" (no speed set and shows white instead of blue on status displays).
On my wife's new 26 Badlands, it looks like a speed must be set and status showing in blue for the automatic distance keeping and braking for a slowing vehicle in front to work? Do I have this right? A difference in how Toyota and Ford ADC works?
2025 Badlands Sasquatch
Yes, ACC must be enabled/active for the distance-keeping and speed up/down features to function. In traffic, it will slow to a complete stop and resume acceleration up to the set speed without intervention.
There is, however, Automatic Emergency Braking which does not depend on ACC. AI overview of Ford AEB:
"The Ford Bronco Sport features standard Pre-Collision Assist with Automatic Emergency Braking (AEB), designed to detect vehicles or pedestrians ahead and automatically apply the brakes if a collision is imminent and the driver doesn't respond. This system uses camera and radar to help prevent or mitigate crashes. [1, 2, 3, 4]
Key Aspects of the Bronco Sport AEB System:
  • Three-Stage Response: Detects risks and emits audible/visual alerts, pre-charges the brakes for faster response, and finally applies full AEB if necessary.
  • System Capabilities: It can detect stationary vehicles, moving vehicles, and pedestrians, even in certain nighttime conditions.
  • Settings Adjustment: Driver alertness and system sensitivity can be adjusted to high, normal, or low in the instrument cluster menu.
  • Limitations: Camera and radar sensors may have reduced efficiency in poor weather conditions (fog, snow, rain). [2, 5, 6, 7]
The AEB system is part of the Ford Co-Pilot360 safety suite, which is designed to enhance driver awareness and safety. [2]
AI can make mistakes, so double-check responses
[1] https://www.schickerfordstlouis.com/pre-collision-assist-with-automatic-emergency-brak.html
[2] https://www.robsightford.com/ford-bronco-sport-safety-features/
[3] https://www.willisford.com/ford-latest-safety-innovations.htm
[4] https://www.facebook.com/iihs.org/posts/-automatic-emergency-braking-is-applied-in-the-2025-ford-bronco-sport-during-a-r/677167854994427/
[5]
[6] https://www.akinsford.com/blog/how-to-turn-ford-pre-collision-assist-on-off/
[7]
https://pmc.ncbi.nlm.nih.gov/articles/PMC7037779/"
DWG
New Jersey
With Ford ADC you must first engage cruise control. It is really you have a choice to use or not use ADC when you activate cruise control. There is 15 pages dedicated to ADC in the 25 owners manual so you really need to read the manual for all of situations that affect ADC. A small tip regarding what I learned from my Fords: When using ADC and you have slowed down because of the car in front of you I have found that for smooth acceleration it is best to have plenty of room in front of you and start accelerating before you move into the passing lane otherwise if you just steer Ito the passing lane and your vehicle senses it is clear in front of you, your vehicle will accelerate quickly to reach the set speed and it may be faster than you like. Below is an AI summary of how it works.
No, Ford Adaptive Cruise Control (ACC) does not work if the main cruise control system is turned off
. ACC is a functionality within the cruise control system, requiring the driver to activate it via steering wheel buttons (white indicator) and set a speed (green indicator) before it actively manages distance and speed.
Ford +3
Key Details on Ford Adaptive Cruise Control (ACC):
  • Activation: You must press the cruise control on/off button on the steering wheel first.
  • Modes: In the instrument cluster settings (Driver Assistance > Cruise Control), you can select either Adaptive or Normal (conventional) cruise control.
  • Standby/Off: If you press the brake pedal or the "cancel" button, the system goes into standby. The vehicle will not manage speed or distance until you press "Resume" or "Set" again.
  • Overriding: You can override the ACC by pressing the accelerator pedal (e.g., to pass a car), but the system remains active to take over once you release the pedal.
    Ford +4
If you want to use conventional cruise control without the adaptive distance-keeping feature, you must change the setting to "Normal" in the menu.
`Stress01
Jack
Wheaton, IL
2016 Mustang GT, 2025 Bronco Sport Badlands Sasquatch, wife's 2021 VW Atlas SEL
While we are on the subject, has anybody else noticed that when there are several posted speed limits, ie (65 min 45, trucks over 4 tons 60)that the system reads or thinks that the speed limit is 60 and automatically slows the car to 60 when ACC is activated. Is there a way to change that ? It’s annoying. You’re taveling at 65 and all of suddek it slows to 60 because the sigb says 60.
Haven't encountered any dual-speed zones yet. In addition to setting a tolerance (+/- speed limit), you can disable the Predictive Speed Assist entirely if you find it too bothersome:
Ford Bronco Sport 2026 Badlands Adaptive Cruise Control question 1774211868971-zn
`Stress01
Jack
Wheaton, IL
Thanks, i‘ll look into that setting. All of the interstae in the chicagi area have dual zones, or seems to
RC Turner
Southern Minnesota
I would strongly suggest that you deactivate the predictive speed functions. They can cause things to happen that you aren't ready for. It can also result in your vehicle doing things that are not proper for your vehicle depending on current traffic conditions.
DWG
New Jersey
With the ADC on I have noticed while driving on the highway and you are going 65 (local speed limit) and there is traffic ahead that has slowed enough that you have to brake, instead of slow steady braking that I would do the system seems to wait longer than I would to start braking and brakes harder than I would. Of course if I am braking ahead of the system it will turn off and I have to reset it once moving again.
Yeah, I find it too twitchy, braking and accelerating too hard.
davidg4781
Yup! I had to turn that off. I was on the highway cruising at 65 mph and it picked up the 45 mph sign on the feeder and slammed on the brakes. I got off and turned it off right then.
Anyone know if the ACC shows brake lights when slowing (but not stopping)? The braking action is strong enough for me to think so, but there’s no way to tell from inside the car.
I know the hill start button (brake hold) does, I’ve checked it from inside the garage.
Yes, brake lights are on when ACC brakes
More specifically:
When brake lights DO come on
• If ACC actually applies the friction brakes, the brake lights illuminate
• This is because the system uses the same braking system as your foot would
• In general, moderate or stronger deceleration triggers brake lights
When brake lights do NOT come on
• If the vehicle is just coasting or lightly engine braking, no brake lights
•This happens during very gentle speed adjustments where no real brake pressure is needed
of course that’s an AI answer, was not able to find specifics in the 2022 owner’s manual
NMBroncoSport
PJ
My Toyota has red indicator bars in the digital dash display that shows when the brake lights are on during braking (whether automatic braking or with brake pedal). Not sure if the wife's new 26 Badlands with Badlands Tech Package has a brake lights indicator in the dash display.
