Help on Activation of Ford Keyless Entry Keypad
rugedraw
Javier
Miami, FL
No. I haven't been able to get it set up. It's been sitting there for 2 years. Bummer.
Dealers are not helpful here.
On your vehicle that is on Sync 3, you should be able to do it with easy mode in FORScan. If the option isn't there in easy mode, then it is enabled manually here in the BCM:
Ford Bronco Sport Help on Activation of Ford Keyless Entry Keypad 1772656474622-57
And here in the APIM:
Ford Bronco Sport Help on Activation of Ford Keyless Entry Keypad 1772656843142-ay
Whpony96
Scott
Nampa, Idaho
This works on a 2025 Badlands with Sync 4?
rugedraw
Javier
Miami, FL
AlanMac
Alan
2025 Bronco Sport, 1970 Mustang Mach1
I recently purchased a 2025 BS badlands and it had the keypad on the door. The dealer that installed the keypad provided the unique 5 digit factory code so I could program my personnel code per the owners manual. I assume when they installed it they programmed the factory code with the body control module.
Whpony96
Scott
Nampa, Idaho
This is the touch panel i'm referring to.
Ford Bronco Sport Help on Activation of Ford Keyless Entry Keypad M1PZ14A626AB_0
