Factory PIN for Keyless Entry
tallmansd
Scott
Indianapolis, Indiana
I forgot to ask the dealer before I left what the PIN was. I sent them an email, but as impatient as I am, I read the manual. It tells how to see what the PIN is, but I can't find the location of the "Spare Key" socket to do the steps. It looks like it is under the center arm rest, inside the storage, but I don't see anything in there.
Anyone know where it is?
Badlands trim
Thanks
dinglehead
J
Fla
'21 Ford Ranger FX4
Pretty sure you just place your key in to the center console
realworld51
Badlands trim
Thanks
A plastic card with the factory-set PIN should be included in the packet with the owner manual. Not in your packet?
tallmansd
Scott
Tried putting the keys in the center console one at time, following the instructions, no luck.
Also went through the owner manual pouch again, no plastic card. There were tags on my keys, but none of the codes unlock the doors.
Sargent28
J
67 Mustang
It is a small laminated white card the size of a credit card. It was given to me by my dealer not in the manual.
Shiskamba
Tennessee
2015 Ford Focus SE Hatch
There was a separate post (perhaps part of the fuse box post for camera mount?) that said the key location isn’t actually in center console but actually below the center stack in one of the cubbies. Apparently a owners manual mistake...? Worth a try
tallmansd
Scott
Ok, that helped! Found it.
Under the USB-A and USB-C ports, remove that rubber bottom, there is an indentation in the molding. Putting the keys there worked.. But now that I came back inside to post that I found my key.. I forgot it..
Thanks everyone!
Shiskamba
Tennessee
Thanks everyone!
Lol, happy to help.
Chase65
Chase
Kansas
'21 BSFE, '21 BSOBX, '12 F150 FX4, '94 Explorer, '93 YJ
Also you can find they key code under the glove box in the fuse compartment. If you view the thread about the interior fuse box access, you can see how to get to it. The code is on the larger white sticker behind the wires that are partially exposed. You can see the wires I’m talking about in the 6th picture on the fuse access thread: https://www.broncosportforum.com/forum/threads/interior-fuse-block-access.1627/#post-30896
Here is a video showing how to find the key code. It is shown on an Escape, but it’s the exact same process.
Hope this helps!
Kperry62
Massachusetts
Subaru
Badlands trim
Thanks
Mine was on a card in glove compartment.
tallmansd
Scott
Got my title paperwork in the mail yesterday, including the factory pin code for the door!
Central Jersey
Mordechai
NJ
Bronco sport big Bend
Both my keys and the plastic card were given to me on a thin plastic band ( BB purchased from dealer inventory)
tallmansd
Scott
Just an update:
when I received the documents to get new plates from the dealer, they provided the plastic card with the factory pin on it.
