2025 Fender Tie Down Retrofit Diagrams
FuryMachine84
U.S.
2023 Ford Bronco Sport
I'd be more interested in finding pit if the whole fender could be swapped over lol.
And the bumper also.
JPtapt
If you lift the hood of a 2025, you will see some padding right at the firewall. Pull it back and you will see two bolts. Remove them and the whole unit just slides out. Very easy to do. I don't know if earlier models have the threaded bolt holes though.
Ford Bronco Sport 2025 Fender Tie Down Retrofit Diagrams Tiedown1
Ford Bronco Sport 2025 Fender Tie Down Retrofit Diagrams Tiedown 2
black
incavulator
@JPtapt Great pics. Thanks!
I checked my 21 and I assume the two bolts you take out to remove the assembly are the two circled in yellow below?
If so, the pre-25's don't have that entire black bracket circled in green below. I think this, along with whatever those bolts thread into(?) are part of the components that would need to be ordered if someone was going to do the retrofit.
A picture of this same area from my 21 is included before your photo for comparison.
Ford Bronco Sport 2025 Fender Tie Down Retrofit Diagrams 1768016104188-jt
Ford Bronco Sport 2025 Fender Tie Down Retrofit Diagrams 20260109_223705
JPtapt
Yes, you have it right. The two bolts in yellow hold the unit in place they thread through the bracket, and their ends are visible
You are right. The two bolts in yellow thread through the green bracket and come out near the door hinge. I don't know if the hinge assemblies are the same and if you have room for the bracket though.
JPtapt
Here is a pic of the door jamb where the bolts exit through threaded holes.
Ford Bronco Sport 2025 Fender Tie Down Retrofit Diagrams 1000002976
sjw1109
scott
ny
2025 bronco sport
Has any one been able to by these, i have been looking and cant seem to find them
Frenchy906
2025 Bronco Sport Badlands
Still waiting myself. I recently ordered the Sasquatch flares, and I was told initially 2-3 weeks, and now the order is sitting waiting to be fulfilled. With no ETA.
Eventually, I’ll probably just order the pieces to make this work through the dealer myself. 🤣
PONY LOVER
Dan
Monroe, IA
2025 Bronco Sport Badlands, 2022 F150 Super Cab 4X4, 2016 Focus Sport 5DR
I just looked them up & they are available as individual pieces; 2 mouldings, 2 braces, 2 handles & assorted bolts. They totaled up to over $2,600.00. All of these parts are in stock @ the Livonia PDC.
I can provide part numbers if want them after you pick yourself off the floor. It was a hard pass for me.
sjw1109
scott
ny
2025 bronco sport
Definitely got to get up from the floor, they are not worth that much lol.
Thank you
2025 Badlands Sasquatch
And here I thought Tylenol in a hospital was expensive.
PONY LOVER
Dan
Monroe, IA
The stinking cast handles ae $958.00 each. The tie downs are only $495.00 added to the $2,495.00 Sasquatch package on the 2026s. We're always telling the sales dept if you want a King Ranch, Sasquatch, ST, etc. order one, there's no way to economically recreate one from one on the lot.
The stinking cast handles are $958.00 each.
Could probably take a pair, scan and SLS print them for less than half the cost of one.
PONY LOVER
Dan
Monroe, IA
One make the bezel / mouldings with a 3D printer & the brackets wouldn't be terribly difficult.
