Anyone know where the horn is located?
Butterworm
Jason
Calgary AB Canada
2021 Bronco Sport Badlands
And how accessible it is? First thing I want to do is replace it with a twin trumpet. Curious how easy it is to get at and where it is mounted.
shakeandbaker
Austin
Cactus Gray BS Badlands, BMW 135i
Also interested in installing a dual tone horn if someone has found this.
Does anyone know whether the stock BS horn is high or low tone?
Creature612
Samuel
San jose
2021 Ford Bronco sport
The horn is behind the drivers side head light. It looks like you will have to remove the front plate. I bought an aftermarket horn because I hate the beep beep one it has. I think I need additional wiring and a fuse. Probably going to get it professionally installed because it doesn’t look as easy as I thought it would be. I don’t think I can use the existing wiring will most likely have to drill a hole to mount it.
brockdog12
NTX
For those that have swapped horns have you had to add a relay or anything? This single horn has got to go. Thanks!
johnardsg
johnard
Texas (previously from PNW)
2021 BS BigBend/2011 v6 Rav4
I’d locate it by having my best friend stand in front of the Sport while I’m inside constantly pressing the horn. :crazy:
never really have to beep beep honk here in OR, 98%ish don't use it hehe
but good to know where to change it, thanks!
21Broncosaurus
Ish
SoCal
21 Bronco Sport
Subaru guys use Hella Horns. I wonder if we can retrofit them behind the grill somewhere.
Adam06
Adam
New Mexico
Bronco sport big bend
Isn’t it on the steering wheel ?
I can't believe someone would ask that question.
Lazy azz.
CrazyKZ
Ken
Allen, TX
