Does anybody know the part number for this rubber foot?
zachc275
Zach
BS Outer Banks (Area 51)
For almost 2 years now I’ve been driving with this rubber foot missing from one of the legs of the cargo management system. Because of this, the leg does not snap into the shelf/rack/whatever you want to call it and sometimes bounces around while I drive. I’ve tried looking before for the part number, but have had no luck. No clue if they’re even is a part number. Anybody know by chance? I’m sure I could jerry rig some thing but I wanted to look at least a little decent.
View attachment 60242 View attachment 60243
The cargo management system is sold only as an assembly:
Cargo management system/table: l
M1PZ-7813046-GA
Side trim panels required for system:
LH: M1PZ-7831013-BA
RH: M1PZ-7831012-BA
No separate Ford part number exists
If you can take off one of the rubber feet you have left and in sure you know you can take that to an ACE Hardware if there is one near you - or any larger hardware stores which often have bins of parts trays and likely have a rubber foot that will fit
2025 Badlands Sasquatch
This. Don’t even worry about a match, just get a pair you like with the same ID as the original and you’re good to go.
I lost one as well. I found a vinyl protective cap in one of my bins of crap. Like others said, check your local hardware store, Ford won’t have it.
I measured the leg. It’s a bit over 16mm or 5/8 of an inch. This kit should cover what you need.
MOCAP Round Vinyl Plastic Caps – Medium Cap Kit (7/16", 1/2", 9/16", 5/8", 11/16") | Durable, Flexible Vinyl Caps for Thread Protection, End Caps, & Surface Finishing - 10 Units Each Size https://a.co/d/0ciNprMC
Ford Bronco Sport Does anybody know the part number for this rubber foot? IMG_4763
ScareCrow
Burl
Indiana
BS/Badlands
