U3012-68 dtc code
tekoontz
Terry
New Mexico
2025 Ford Bronco Sport
Has anyone gotten a U3012-68 dtc code ?
rugedraw
Javier
Miami, FL
Which module?
There would be two other characters after the 68.....what were they?
tekoontz
Terry
New Mexico
Fixd device
full code was U3012-68
rugedraw
Javier
Miami, FL
I can't make any sense out of that. If your fordpass is connected, message me the VIN and I'll pull the connected data on it.
rugedraw
Javier
Miami, FL
Code is for improper wake-up of the ABS module after a key cycle. Nothing to worry about it all. The code shows a 28 at the end which means it is a stored code and not an active fault. You can ignore it.
Ford Bronco Sport U3012-68 dtc code 1769211641054-v8
Also, you have an OTA for the APIM sitting in your queue since yesterday. All you need to do is start the truck and check for updates to give it consent to download and install.
Ford Bronco Sport U3012-68 dtc code 1769211750009-gr
Frenchy906
2025 Bronco Sport Badlands
Code is for improper wake-up of the ABS module after a key cycle. Nothing to worry about it all. The code show a 28 at the end which means it is a stored code and not an active fault. You can ignore it.
Hey, since you’ve got the ability to check stuff, may I message you for something?
tekoontz
Terry
New Mexico
Thanks !
How did you get the readout ?
HotRod4321
Rod
Alpharetta GA
2024 Ford Bronco Sport Big Bend Chille Red
From Bing search:
Maybe helpful? Suggest turn off. Rest. Firmly press on brake and restart and wait for car to normalize. Unfortunately, cars are now computers, and we have to wait for the circling circles or spinning sand watches! LOL! Godspeed in your search for a solution and PLEASE post results when you get them. Thx in advance!
SSM 53683 2025 F-150/Expedition/Navigator/Bronco/Ranger - DTC U3012:68 Stored In The ABS Module
Some 2025 F-150/Expedition/Navigator/Bronco/Ranger vehicles may exhibit diagnostic trouble code (DTC) U3012:68 stored in the anti-lock brake system (ABS) module with a soft brake pedal following vehicle start-up with various brake system illuminated warning lamps and/or brake-related messages displayed in the instrument panel cluster (IPC). This may be due to a controller area network (CAN) communication concern within the ABS module. Replacement of the ABS module will not resolve this condition. To resolve this condition, place the vehicle in park. Disengage the park brake. Turn the vehicle off. Close all doors and liftgate/tailgate. Allow the vehicle to sit for 5 minutes to allow all vehicle modules to power down. Restart the vehicle. Verify brake functionality and clear any DTCs. Pressing unlock/lock button on the key fob, opening the doors/liftgate/tailgate or keeping the key fob within 30 ft (8 meters) of the vehicle can prevent the modules from powering down completely. Inform customers that they can continue to drive the vehicle and engineering is currently working on a solution for this condition that is expected in Q3 2025. Monitor Professional Technician System (PTS) for additional information and schedule service appointments for customers once the repair becomes available.
