U3012-68 dtc code
tekoontz
Terry
New Mexico
2025 Ford Bronco Sport
Has anyone gotten a U3012-68 dtc code ?
rugedraw
Javier
Miami, FL
Which module?
There would be two other characters after the 68.....what were they?
tekoontz
Terry
New Mexico
Fixd device
full code was U3012-68
rugedraw
Javier
Miami, FL
I can't make any sense out of that. If your fordpass is connected, message me the VIN and I'll pull the connected data on it.
rugedraw
Javier
Miami, FL
Code is for improper wake-up of the ABS module after a key cycle. Nothing to worry about it all. The code shows a 28 at the end which means it is a stored code and not an active fault. You can ignore it.
Ford Bronco Sport U3012-68 dtc code 1769211641054-v8
Also, you have an OTA for the APIM sitting in your queue since yesterday. All you need to do is start the truck and check for updates to give it consent to download and install.
Ford Bronco Sport U3012-68 dtc code 1769211750009-gr
Frenchy906
2025 Bronco Sport Badlands
Code is for improper wake-up of the ABS module after a key cycle. Nothing to worry about it all. The code show a 28 at the end which means it is a stored code and not an active fault. You can ignore it.
Hey, since you’ve got the ability to check stuff, may I message you for something?
tekoontz
Terry
New Mexico
Thanks !
How did you get the readout ?
