JCR Hatch Molle Panel installed
pixlpush
Portland, OR
I installed the JCR Hatch MOLLE Panel today. At first it’s a little intimidating since you have to remove the entire hatch interior panel, drill six holes, and mount the panel using carriage bolts and spacers. In practice, though, it really wasn’t that bad.
The panel is rock solid and gives me a great spot to mount gear that’s easy to access whenever the hatch is open. Now I just need to guess the odds on my wife getting hit in the head by the shovel before I actually use it to dig myself out 😆
Ford Bronco Sport JCR Hatch Molle Panel installed IMG_1913
Ford Bronco Sport JCR Hatch Molle Panel installed IMG_1914
Ford Bronco Sport JCR Hatch Molle Panel installed IMG_1915
Ford Bronco Sport JCR Hatch Molle Panel installed 55C1CDF1-9D99-4608-A00D-6DEE87412C19
dockiwi57
21 Mazda CX5 Sig
The panel is rock solid and gives me a great spot to mount gear that’s easy to access whenever the hatch is open. Now I just need to guess the odds on my wife getting hit in the head by the shovel before I actually need it to dig myself out 😆
Wife? I'm more worried about me.
I hope those struts are able to handle the extra weight.
Luckily that’s a fairly straightforward upgrade if required.
pixlpush
pixlpush
Portland, OR
So far so good even on a cold day. I don’t plan on putting real heavy items up there but things do add up. Time will tell but I’m not too concerned.
SHAKEmeBUNS
George
2022 Bronco Sport Outer Banks
You're correct, the struts struggle to keep the hatch up, even worse when it's loaded. Everything you attach there will hit you in the forehead, and if you have the cargo management shelf, like I do, you have space things out so it misses the shelf.
Mwittke5857
Elma, NY
2021 Bronco
For whatever reason, once I attach something to mine, it pulls out the push pins and yes, I have replaced them with new ones
pixlpush
pixlpush
Portland, OR
How do you like that shovel?
I like it for what it is. It’s the one I always have with me and it’s better than one of those fold trenching tool style shovels. I bring a full-size shovel mounted to my roof rack for longer trips in the dirt/mud. This one is good in the sand. It’s also very light which hopefully will give the hatch struts a fighting chance of staying open which so far has been no problem.
pixlpush
pixlpush
Portland, OR
well that’s a bummer. I can see how those push in fasteners on the hatch panel might not be up to the task of holding additional weight.
it might be more trouble than it’s worth but I wonder if a couple of well nuts in place of the snap in fastners would hold better. Getting them in the right spot would be tricky though.
Ford Bronco Sport JCR Hatch Molle Panel installed 1768583177454-bk
Mwittke5857
Elma, NY
2021 Bronco
I was thinking riv-nuts and sandwich the molle and factory panel to the hatch. However, I'm trading the ole gal in so I'm removing it and plugging the holes with flat push pins.
