The Dreaded Clunk
sandog
Lee
Northern Arizona
A few months ago I downsized, traded in my 2019 Ranger for a BS BB. I thought it looked good with the Falken tires but had no idea at the time it had a lift kit.
A 1.5" lift isn't a real big change. I knew the new Bronco Sport was stiffer than my 2wd Rnger was, going around round-a-bouts there was less body roll, and going over speed bumps was more tame.
My main dislike was the much lower clearance of the Bronco Sport, I had no problem sliding under the Ranger without jacking it up to check things or change fluids.
The last couple months I've been enjoying looking for gold in the Bradshaw Mountains northwest of Phoenix. I don't find any often but enjoy looking and learning about geology.
I don't drive fast on dirt roads, even if they are fairly smooth. I keep it under 30. I remember all the rock chips by Ranger had down the sides and I didn't drive it fast or hard either. Rougher sections and washboard I slow down to a crawl. I'm in no hurry, but a lot of trucks and jeeps will come flying up behind doing 65, even if there are curves and hills. They all think they are in the Mint 400 race I guess.
A couple weeks ago, after I got home from a trip near Bumblebee, I started hearing a loud clunk whenever I hit anything more than a small bump.
It seemed to be coming from near the left front wheel but I could'n be sure, it might be from near both wheels.
I took off the splash shield and checked struts, sway bar kinks and the fasteners were tight.
I figured maybe a strut went bad and the rig was under warranty, so I made an appt. with the dealer.
I got a call when they got around to looking at it and they asked " Did you put a lift kit on this "? I said "no, but about 30 minutes before I had looked through the service records and saw that I had overlooked a lift kit being installed by a rival Ford dealer down in Phoenix. The Bronco was a month old and the dealer, Earnhart, installed a Rough Country 1.5" lift (the $200 one, not the $700 one) and replaced the wheels and tires with the Falken AT3 on Black Rhino rims.
The first owner bought it a couple months later and must have never taken it off road or near shopping carts. Not even a minute scratch or chip anywhere.
The dealer kept the rig over the weekend, long enough to check on new end links from Rough Country, they are backordered.
I started reading threads here about the early RC lifts that the end links were not the greatest. Lots of guys getting the clunking noise.
One guy said that Rough Country responded and sent him out some improved links, but he was the exception, most said they couldn't get RC to answer back.
Some have stated that the problem is merely loose nuts on the links that nylon lock nuts are needed over the RC non locking.
Mine are tight, but the bushings do look damaged at full wheel lock.
I read where some here just put the OEM sway bar link back on and said the ride quality was much improved. Wouldn't those be a bit (1.5") short to use with the spacer lift ?
And others said they went with HRG end links, a better product than RC. I might go that route, but wanted to hear what other's solutions to the RC end links were.
Ford Bronco Sport The Dreaded Clunk 20251006_145849
Ford Bronco Sport The Dreaded Clunk 20251006_145827
sandog
sandog
Lee
Northern Arizona
I received the HRG Offroad end links a couple days ago and today installed them.
The driver's side old link was the worst, the right one wasn't shot but the rubber in them was flattened and cracked.
Maybe they failed early because they weren't the right length ? The old links are a good 1.5 inches shorter than the new HRG ones. When the lift kit was installed at the other Ford dealer, they should have used the new longer links that came in the kit, looks like maybe they didn't.
The old links have regular nuts that don't stay tight, so maybe they were the Rough Country links ?
The new ones have Nylock nuts.
I took it for a test drive, no more annoying clunk. :D
Ford Bronco Sport The Dreaded Clunk 20260109_130208
Ford Bronco Sport The Dreaded Clunk 20260109_130212
Chiefthepup
Colt
Washington
Glad it got fixed!!
I read these stories and am super pleased with my decision to go with Eibach spring lift. No spacers or end links etc. just taller springs.
Unicorn
Chester
W. WA
BS Badlands with Sasquatch.
Glad it got fixed!!
the problem with those, if you off road that is, is that you lose droop. You gain the height by the springs pushing the vehicle up so you're closer to full extension from the start. Wheel goes in a hole and it can't move down as far so you're more likely to three wheel with either that wheel in the air, or the opposite corner. I've done this in the past with spring lifts in a different CUV and on most of the uneven areas I was on three wheels and sometimes that reduced my traction.
S Duncan
Duncan
winn70
Nth Iowa
2023 Ford
Gonna read this as mine has a clinking noise underneath.
Our clunking sound was a worn out sway bar at 35,000. Tech had not seen that before at low miles. No lift kit.
