Spare tire mount
Ironman482
Ronald
Buchanan dam Texas
2023 bronco sport
I might raise the tire a few more inches to give the camera a better view, it works like it is ,but I would like a little more view to the right , in the Pic the license is blocked a little but if I backed up a few feet I can see it fine.
Ford Bronco Sport Spare tire mount 20251224_143217
Ironman482
Ronald
Buchanan dam Texas
2023 bronco sport
My next project will be a roof rack , don't like any of the ones i see online ,and I think I have enough aluminum tubing to build the one I want , any recommendations for the cross bars , that don't ride to much above the rails ?
Nice job on the work but it looks like aftermarket and off.
Ironman482
Ronald
Buchanan dam Texas
2023 bronco sport
Update, finished the EM bike rack , all aluminum, turned out pretty good , I wanted to keep the length as short as possible, so I made it with the frt tire turned , my aluminum welding skills need improvement, but I'm working on it , next project aluminum roof rack.
Ford Bronco Sport Spare tire mount 20260101_111242
Ford Bronco Sport Spare tire mount 20260101_111254
Ironman482
Ronald
Buchanan dam Texas
2023 bronco sport
This is my home made tire carrier
Ford Bronco Sport Spare tire mount 20220805_221113
Ford Bronco Sport Spare tire mount 20230124_204556
That nut and bolt to the right of the latch, does it attach to the hidden recovery threaded port , if so what is the size and thread pitch , was wanting to use that port to stabilize my design.
Wabarca2
Walter
That's what I used it for, I could not find it because it's reverse tread so I bought a recovery point bolt and cut it and welded 3/4 rod to it.
Ford Genuine Ford 6M2Z-17A954-A Recovery Hook
cprcubed
Parker, TX
IIRC, the Recovery Eye is left-hand threaded. I forget the size and pitch. Cheers!
Nice work! If I had your welding skills I'd add a rack for a gas can on the left side. Off-raod, the gas mileage goes down to about 10 mpg.
