Bilstein b8 terrasport
wireman
Murrieta
Bilstein 24-316415 BIL B8 Series Shocks for the rear. Bought two. Each one comes with one shock and one kit to lift that wheel end. I installed installed only the shocks. 2024 Badlands.
Photo?
DesertRat19
Will
Phoenix
Doesn’t that look weird lifting only the back? Or did you already have a leveling kit installed?
TheX
Randy
Austin TX
www.netwerkin.com
I know they can be bought separately, can they be installed in only rear or only front? I ask because if it's providing a 1.25" lift in the rear wouldn't the tilt be more pronounced?
I wouldn't install just front or rear. I'm tempted to put them on my Sasquatch.
DesertRat19
Will
Phoenix
The rear shocks come with spring spacers so they dont lift on their own. The front struts are built longer.
ah, thanks. well I won't be installing them for a while it seems.
Gapbriel
Gapbriel
Gabriel
Argentina
For the guys who installed the bilstein b8 , is it well installed like this ? Do I need another supplement ? I have that doubt , because I see that the rear part increment a little bit not than the front .. sorry for my English
Ford Bronco Sport Bilstein b8 terrasport IMG_5998
Garth
Garth
Ontario
It looks like you have the spacer there, I will look at mine tomorrow and compare
Frenchy906
2025 Bronco Sport Badlands
Looks just like mine. I did it myself.
For the bottom: Spacer goes on the control arm. Lower strut isolator goes into spacer. Spring goes into isolator.
For the top: Trailing arm spacer goes in between body and trailing arm. Upper isolator is left untouched. Spring goes into isolator.
Gapbriel
Gapbriel
Gabriel
Argentina
Awesome thanks 🙏🏽 my friend
Garth
Garth
Ontario
The Sasquatch might not benefit from these, it already has probably even better suspension with more actual travel, although the ride height is different. Someone installed a spacer kit on another thread, that might be the way to go.
Gapbriel
Gapbriel
Gabriel
Argentina
Yeah, in my case, the travel with the B8 Terrasport is shorter than with the OEM shocks, but it provides better driving on off-road roads. For the sasquatch.. did you take a look to flatout suspension ? , could be those compatible with sasquatch ...
DesertRat19
Will
Phoenix
Picked up from The Custom Shop. Charged $750 for install and alignment.
Ford Bronco Sport Bilstein b8 terrasport IMG_6394
Ford Bronco Sport Bilstein b8 terrasport IMG_6395
DesertRat19
Will
Phoenix
Height before:
Ford Bronco Sport Bilstein b8 terrasport IMG_6317
Ford Bronco Sport Bilstein b8 terrasport IMG_6318
