Bronco Sport Badlands - Lift Options
incavulator
Scott
Check your trailing arm spacers
My noise is definitely not coming from the rear. All strut bolts and sway bar bolts are tight....I don't think this is suspension related. If anything, it might have to do with the cold. This is the first I've driven it since the temps really dropped and at the same time, the lift was installed. I think it's just coincidence.
Frenchy906
2025 Bronco Sport Badlands
Same with me. Haha. I got mine in May this year, and temps were already in the 60s/70s. Now they’re single digits. Just happened to install my struts at the same time of the super cold
Frenchy906
Frenchy906
Yeah sorry thats what I was doing too but I was surprised by the 91+ octane recomendation.
I’m not. It’s a turbocharged engine. They should all be running mid grade at a minimum. Yes, the computer will advance or retard timing and AF depending on the fuel it receives, but still.
Once my “free” tank of fuel was gone in the bronco, I’ve run nothing but 91+ since.
incavulator
Scott
The 2021 2.0L says it was designed to operate on 87 octane. I'm wondering if they had to throw some more spark or boost at it to make the HP numbers on the 25. If so, that may have been the reason they upped the fuel recommendation to 91.
Garth
Garth
Ontario
Yes a little lift and those larger tires look right at home. I just noticed they were Toyos, same as mine. I got them for the winter and they have been excellent.
On ice and snow miles better than the Continental cross contact atr.
Probably not as good as straight snows but mine arent coming off till they are worn out.
Frenchy906
Ford Bronco Sport Bronco Sport Badlands - Lift Options IMG_2775
I’m having good luck with the Wildpeaks… I did run into a traction control slip up trying to back up in the snow, but turned it off, and it walked out no problem.
I guess trying to back up through 12” of snow probably wasn’t the wisest decision. 🤣
SHAKEmeBUNS
George
2022 Bronco Sport Outer Banks
Here is a before and after of the RTR 1.30" leveling kit. I think they make the Larger 245/65/17s sit better. Install was easy-ish and the stance is not overdone. (Windows down is the before)
You can't really tell, but before I installed the leveling kit, the Bronco did look squatty with the bigger wheels...
I think the Bronco is tilted down at the nose. Looks like there's more lift in the front.
It's a significant difference when I part next to a stock BS...
Ford Bronco Sport Bronco Sport Badlands - Lift Options Screenshot_20251231_115632_Gallery
Ford Bronco Sport Bronco Sport Badlands - Lift Options Screenshot_20251231_121722_Gallery
Ford Bronco Sport Bronco Sport Badlands - Lift Options 20251115_164502(1)(1)
Frenchy906
Agreed. Bigger tires and no lift, it looks squatty.
Ford Bronco Sport Bronco Sport Badlands - Lift Options IMG_2116
