Bronco ForScan Thread
rugedraw
Javier
Miami, FL
I already sent them a message but they didn't reply :crying:. Do you remember which version of Forscan they sent you? Thanks
One thing I've noticed is that they seem to respond quicker to people with the paid license more than the free one. Either way, I would try emailing them again. I emailed them two days ago and got a response the next day saying they were working on my request and sent me a test build today.
pantera155
Pantera
Argentina
Bronco
Solved! I had to use an older version of Fodscan. Thanks everyone.
Summers22
Jon
Went to disable the seatbelt pop up in the IPC, but my module only goes to 720-11-02, well 720-13-01 through 720-14-02 needs modified. I am using a Vgate vLinker. I just did other modules with it yesterday such as high beam fade on, climate to sync screen, bambi mode. Anyone else have this issue?
rugedraw
Javier
Miami, FL
IPC does not go past 720-11-02 on these vehicles.
Edit: For 2021-2024 vehciles. 2025+ are different.
Summers22
Jon
Well thats good and bad I suppose. Is there a module I can modify to get rid of the dash warning of what seatbelt isn't buckled ? That popup is annoying. Thabks
rugedraw
Javier
Miami, FL
I'll dig around to see what I can find. I used the spreadsheet for the Maverick and the Explorer for these trucks as they seem to be the closest thing out there to them.
What speadsheet were you looking at?
Summers22
Jon
The Maverick and Escape spreadsheets matched up from my web searches
rugedraw
Javier
Miami, FL
Try this from the 2023 Explorer spreadsheet:
Ford Bronco Sport Bronco ForScan Thread 1765206635005-66
My 2023 shows this:
Ford Bronco Sport Bronco ForScan Thread 1765206529300-5a
e,
Assuming yours also has a 6 there, I would change it from 6 to a 0 to disable everything in that location and then reboot the IPC from the wrench icon menu.
Summers22
Jon
I will try that this evening, thank you. I have a feeling its just for the chimes and not the seating diagram that pops up in the cluster showing which occupied seat is buckled or unbuckled, but maybe it will be progress and a future entry for a Bronco Sport spreadsheet.
rugedraw
Javier
Miami, FL
There are other things you can try if you're the FAFO type, but some things have very easy and inexpensive solutions where it is not worth racking your brain over it. I just use these in my vehicles. I want the seatbelt minder to work for when my kids are in our vehicles.
https://www.walmart.com/ip/2Pcs-Car-Safety-Seat-Belt-Buckle-Clip-Car-Styling-Universal-Vehicle-Mounted/17564071122?wmlspartner=wlpa&selectedSellerId=102502503&adid=2222222222717564071122_102502503_14069003552_202077872&wl0=&wl1=g&wl2=c&wl3=42423897272&wl4=aud-430887228898:pla-2449037643288&wl5=9011924&wl6=&wl7=&wl8=&wl9=pla&wl10=5397149991&wl11=online&wl12=17564071122_102502503&veh=sem&gad_source=1&gad_campaignid=202077872&gbraid=0AAAAADmfBIrI75tGAKFokkVllwhVFUEl7&gclid=Cj0KCQiAi9rJBhCYARIsALyPDtuA1la1slwFjldjZpeaRRWkBB1wxP263A36PRfhoKGnD3iqS-nzK2caAth4EALw_wcB
Summers22
Jon
I have 5 adult children all out of the house and just our 14 year old left. We went shopping yesterday and the 3 back seat passengers weren't always the fastest at buckling. I may just live with it if I cant find and easy Forscan solution.
